- To:
- Subject: Re: [cgal-discuss] Hausdorff distance - bad alloc
- Date: Fri, 9 Feb 2018 18:13:36 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
My guess is that with 4000 sample points and the total
area of your mesh there are too many points.
Maybe post a small program and the mesh, so that we
can have a closer look.
andreas
On 2/9/2018 4:54 PM, nolvis wrote:
Hello!
I am trying to use approximate_Hausdorff_distance on CGAL::Surface_mesh_3
data structure meshes, but after +- 30 seconds of calculations i'm getting
every time bad alloc .
Code was taken from PMP example:
std::cout << "Approximated Hausdorff distance: "
<< CGAL::Polygon_mesh_processing::approximate_Hausdorff_distance
<TAG>(mesh1, mesh2,
CGAL::Polygon_mesh_processing::parameters::number_of_points_per_area_unit(4000))
<< std::endl;
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Hausdorff distance - bad alloc, nolvis, 02/09/2018
- Re: [cgal-discuss] Hausdorff distance - bad alloc, Andreas Fabri, 02/09/2018
- Re: [cgal-discuss] Hausdorff distance - bad alloc, Sebastien Loriot (GeometryFactory), 02/12/2018
