cgal-discuss - Re: [cgal-discuss] CGAL::write_xyz_point_set precision and normal problem
  • To:
  • Subject: Re: [cgal-discuss] CGAL::write_xyz_point_set precision and normal problem
  • Date: Sun, 11 Feb 2018 19:06:25 -0700 (MST)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=Pass
  • Ironport-phdr: 9a23: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
Thanks for your kind suggestion.
I managed to change the normal estimation code to use jet_estimate_normals:
CGAL::jet_estimate_normals<Concurrency_tag>(
point_sets,
12,
CGAL::parameters::point_map(point_sets.point_map()).
normal_map(point_sets.normal_map())
However, it throws some unknown exception after long running on a large
model.
Any advise on what might happen?
Thanks.
