cgal-discuss - [cgal-discuss] Convert points and circles from 2D linear kernel to 2D circular kernel?
  • To:
  • Subject: [cgal-discuss] Convert points and circles from 2D linear kernel to 2D circular kernel?
  • Date: Tue, 13 Feb 2018 15:58:38 +1100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Hi,
I have a bunch of CGAL 2D points and 2D circles that are parameterized
by a 2D linear geometry kernel (in this case
CGAL::Exact_predicates_exact_constructions_kernel).
I'd like to create 2D circular arcs using these linear points and
circles as construction parameters. I can see the relevant circular
arcs are not in the linear 2D geometry kernel but the 2D circular
geometry kernel. (Although there is a Circle_2 in the linear kernel
but no arcs).
So I need to create instances of Circular_arc_2 parameterized by (say)
CGAL::Exact_circular_kernel_2. For that I need instances of
Circle_2<Exact_circular_kernel_2> and
Circular_arc_point_2<Exact_circular_kernel_2>. Is there a
straightforward way or indeed, any way, to convert the linear kernel
circles and points I have between these two kernels?
Thanks in advance,
Stu
