cgal-discuss - Re: [cgal-discuss] Looking for example of 2D beziers from non-rational control points...
  • To:
  • Subject: Re: [cgal-discuss] Looking for example of 2D beziers from non-rational control points...
  • Date: Wed, 14 Feb 2018 10:26:57 +1100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
On Wed, Feb 14, 2018 at 2:07 AM, Efi Fogel
wrote:
> If you use the CGAL::Gmpq number type or the number type defined by one of
> the predefined kernels, you can simply initialize it from double.
Thanks for the hint Efi. Much appreciated.
Stu
