cgal-discuss - [cgal-discuss] About wlop_simplify_and_regularize_point_set()
  • To:
  • Subject: [cgal-discuss] About wlop_simplify_and_regularize_point_set()
  • Date: Sun, 11 Feb 2018 02:04:58 -0700 (MST)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=Pass
  • Ironport-phdr: 9a23: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
Hi All,
I have been trying out the function wlop_simplify_and_regularize_point_set()
in CGAL v4.12 master build, trying to simplify and regularize my very dense
scanned point cloud in .las format, where it comes with RGBI property.
The result looks very good, however, I am facing two issues unsolved, and
would like to seek advise:
1. The output of wlop_simplify_and_regularize_point_set() is only a list of
points with only position information. From my understanding on how WLOP
works, my points are not just sampled, but some of them also re-positioned.
Thus, how am I suppose to map back my RGBI from my original point set to the
new WLOP processed point set? Or otherwise, the color info is lost.
2. Instead of color, I might later on want to input a point set with texture
coordinates. Similar with problem 1 above, how am I suppose to retain (or
remap) the texture coordinates to the new WLOP processed point set?
Thank you, and hope I could get some advise here.
William
