cgal-discuss - Re: [cgal-discuss] Surface_Mesh_Deformation help
  • To:
  • Subject: Re: [cgal-discuss] Surface_Mesh_Deformation help
  • Date: Fri, 23 Feb 2018 09:59:45 -0700 (MST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
Thank you for your contribution, I've finally managed to solve all of that,
actually there was also an error in processing the vertices, I was
considering starting from 1 instead of 0. I have another issue now, is there
a way to get the number of vertices of a mesh from the mesh object? I've
read the documentation and can't find anything like mesh.size_of_vertices()
or something similar. Should I refer to the vertex iterator or is there a
simpler way?
Thanks in advance.
LV
