- To:
- Subject: Re: [cgal-discuss] lloyd optimization mesh 2 assertion failure
- Date: Fri, 23 Feb 2018 17:00:18 -0700 (MST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=PermError ; spf=Pass
- Ironport-phdr: 9a23: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
Ok this is odd. I made some changes this morning (nothing related to my
constraint code) and recompiled, problem is gone. I can run the domain with
lloyd optimization without issue. However, the resulting "optimized" mesh is
of poor quality. Many small, thin (non-Delauany) triangles are present along
the constraint (circled in red). I've attached an image to show what I mean
where I ran max of 100 lloyd iterations. Is this expected behaviour? All the
other meshes I run lloyd iterations on produce high quality meshes.
<http://cgal-discuss.949826.n4.nabble.com/file/t375307/File_001.png>
- [cgal-discuss] lloyd optimization mesh 2 assertion failure, Chris Marsh, 02/23/2018
- Re: [cgal-discuss] lloyd optimization mesh 2 assertion failure, Jane Tournois, 02/23/2018
- Re: [cgal-discuss] lloyd optimization mesh 2 assertion failure, chrism, 02/24/2018
- Re: [cgal-discuss] lloyd optimization mesh 2 assertion failure, Jane Tournois, 02/26/2018
- Re: [cgal-discuss] lloyd optimization mesh 2 assertion failure, chrism, 02/26/2018
- Re: [cgal-discuss] lloyd optimization mesh 2 assertion failure, Jane Tournois, 02/27/2018
- Re: [cgal-discuss] lloyd optimization mesh 2 assertion failure, Christophe Riedinger, 02/27/2018
- Re: [cgal-discuss] lloyd optimization mesh 2 assertion failure, chrism, 02/28/2018
