cgal-discuss - Re: [cgal-discuss] Introduction to the community
  • To:
  • Subject: Re: [cgal-discuss] Introduction to the community
  • Date: Thu, 1 Mar 2018 13:31:09 -0700 (MST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Neutral ; spf=Pass
  • Ironport-phdr: 9a23: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
Hello again
By the way..
I'm quite frustrated By Arrangement_2, I would like to have Nurbs traits, in
order to merge bezier trait, circles and conics.
It would be quite handy to have a Polygon_set<Arrangement> templated by a
given arrangement, in order to apply boolean operation of polygons on
arbitrary type of arrangement.
We should have hybrid point location strategies, and hybrid insert
strategies, with a profiling tool, in order to calibrate some scalar
parameters to enhance performances.
we should remove completely everything related to Homogeneous kernels, there
are useless.
We should add much more support for interoperability between differents
packages of CGAL, and also more uniformity between different packages. So
much fragmentation !
What do you think ? Would it take 200 men/years or 500 men/years to achieve
that ?
Cheers,
Florian
