- To:
- Subject: Re: [cgal-discuss] Introduction to the community
- Date: Fri, 2 Mar 2018 10:03:41 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
(Why is this discussion happening in the thread "Introduction to the community"? This does not seem related at all. Please open new threads to start new discussions.)
HiIt should. If you take this example: https://doc.cgal.org/latest/Mesh_2/Mesh_2_2mesh_class_8cpp-example.html
Your solution does not seem to work for constrained Delaunay Mesh
and replace `typedef CGAL::Triangulation_vertex_base_2<K> Vb;` by `typedef CGAL::Triangulation_vertex_base_with_info_2<int, K> Vb;` as Mael suggested (with the corresponding include), it works perfectly well.
It is hard to help you if you don't share at least some error messages.
We should have hybrid point location strategies, and hybrid insertWho is "we"?
strategies, with a profiling tool, in order to calibrate some scalar
parameters to enhance performances.
we should remove completely everything related to Homogeneous kernels, there
are useless.
We should add much more support for interoperability between differents
packages of CGAL, and also more uniformity between different packages. So
much fragmentation !
What do you think ? Would it take 200 men/years or 500 men/years to achieveFeel free to contribute: https://www.cgal.org/review_process_rules.html
that ?
Simon Giraudot, PhD
R&D Engineer
GeometryFactory - http://geometryfactory.com/
- Re: [cgal-discuss] Introduction to the community, Florian Prud'homme, 03/01/2018
- Re: [cgal-discuss] Introduction to the community, Mael Rouxel-Labbé, 03/01/2018
- Re: [cgal-discuss] Introduction to the community, Simon Giraudot, 03/02/2018
