cgal-discuss - [cgal-discuss] Mesh reconstruction from Point cloud
  • To:
  • Subject: [cgal-discuss] Mesh reconstruction from Point cloud
  • Date: Wed, 28 Mar 2018 16:20:36 +0530
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23: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
Hello,
         I have a point cloud in "File_name.xyz" format and I need to obtain a mesh for that (surface reconstruction problem).
        I used this ( https://doc.cgal.org/latest/Poisson_surface_reconstruction_3/Poisson_surface_reconstruction_3_2poisson_reconstruction_function_8cpp-example.html ) code for that purpose.
        But when I tried running it, was giving the following error:
fatal error: CGAL/poisson_surface_reconstruction.h: No such file or directory
I also tried pasting "poisson_surface_reconstruction.h" in that folder and then running.
But that didn't work out..
Can someone help me out, Please?
Regards,
Abilash
