cgal-discuss - Re: [cgal-discuss] Mesh reconstruction from Point cloud
  • To:
  • Subject: Re: [cgal-discuss] Mesh reconstruction from Point cloud
  • Date: Wed, 28 Mar 2018 12:57:12 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
This section:
https://doc.cgal.org/latest/Manual/installation.html#title0
tells you how to get started with compiling a cgal example.
Sebastien.
On 03/28/2018 12:50 PM, R Abilash wrote:
Hello,
         I have a point cloud in "File_name.xyz" format and I need to obtain a mesh for that (surface reconstruction problem).
        I used this ( https://doc.cgal.org/latest/Poisson_surface_reconstruction_3/Poisson_surface_reconstruction_3_2poisson_reconstruction_function_8cpp-example.html ) code for that purpose.
        But when I tried running it, was giving the following error:
*fatal error: CGAL/poisson_surface_reconstruction.h: No such file or directory*
I also tried pasting "poisson_surface_reconstruction.h" in that folder and then running.
But that didn't work out..
Can someone help me out, Please?
Regards,
Abilash
