- To:
- Subject: [cgal-discuss] Building 4.11 demos using CMake on Windows
- Date: Tue, 3 Apr 2018 10:08:23 -0700
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
Hi,
I am trying to build CGAL 4.11 demos using CMake and Visual Studio 2017 64-bit on Windows.I can generate nearly all the examples ( which of course require CGAL to build and run ), and some of the demos but CMake is not generating many of the demos with the following error message.
-- Configuring demo in demo/Polygon
Requested component: Qt5
Requested component: Core
Requested component: MPFR
Requested component: GMP
NOTICE: This demo requires CGAL, CGAL_Core, and Qt5, and will not be compiled.
What I don't understand is why is is complaining about CGAL(??) and Qt5 not being available when they are properly configured in CMake along with QGLViewer. CMake finds my QT installation correctly.
Thanks
Andrew
- [cgal-discuss] Building 4.11 demos using CMake on Windows, Andrew Cunningham, 04/03/2018
- Re: [cgal-discuss] Building 4.11 demos using CMake on Windows, Sebastien Loriot (GeometryFactory), 04/04/2018
