cgal-discuss - Re: [cgal-discuss] Building 4.11 demos using CMake on Windows
  • To:
  • Subject: Re: [cgal-discuss] Building 4.11 demos using CMake on Windows
  • Date: Wed, 4 Apr 2018 08:29:40 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
The cmake script does the following:
if ( CGAL_FOUND AND CGAL_Qt5_FOUND AND Qt5_FOUND )
Maybe you did not build CGAL Qt5 library?
Sebastien.
On 04/03/2018 07:08 PM, Andrew Cunningham wrote:
Hi,
I am trying to build CGAL 4.11 demos using CMake and Visual Studio 2017 64-bit on Windows.
I have QT 5.7 installed.
I can generate nearly all the examples ( which of course require CGAL to build and run ), and some of the demos but CMake is not generating many of the demos with the following error message.
-- Configuring demo in demo/Polygon
Requested component: Qt5
Requested component: Core
Requested component: MPFR
Requested component: GMP
NOTICE: This demo requires CGAL, CGAL_Core, and Qt5, and will not be compiled.
What I don't understand is why is is complaining about CGAL(??) and Qt5 not being available when they are properly configured in CMake along with QGLViewer. CMake finds my QT installation correctly.
Thanks
Andrew
