- To:
- Subject: Re: [cgal-discuss] visulization in cgal using qt
- Date: Tue, 17 Apr 2018 21:50:30 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:/qPyxh2p4rbu2K+XsmDT+DRfVm0co7zxezQtwd8ZseIVL/ad9pjvdHbS+e9qxAeQG9mDsLQc06L/iOPJYSQ4+5GPsXQPItRndiQuroEopTEmG9OPEkbhLfTnPGQQFcVGU0J5rTngaRAGUMnxaEfPrXKs8DUcBgvwNRZvJuTyB4Xek9m72/q99pHPbQhEniaxba9vJxiqsAvdsdUbj5F/Iagr0BvJpXVIe+VSxWx2IF+Yggjx6MSt8pN96ipco/0u+dJOXqX8ZKQ4UKdXDC86PGAv5c3krgfMQA2S7XYBSGoWkx5IAw/Y7BHmW5r6ryX3uvZh1CScIMb7S60/Vza/4KdxUBLniikHOT43/m/Ul8J+kr5UrQm7qBBj2YPZep2ZOOZ8c67bYNgURXBBXsFUVyFZAI2zcY0PAPccNuhasYb9o0EBrR+jDgSrBOPg1DlIiWLs0a06zeshFRvJ3AgjEt8Vv3TUqc/6NKYWUeyv0KbIyjDDYupQ1Dzg5obIdRUhruuNXbJ2acfRz1MgGBjegVWUt4PpJS+a1uMIs2SD7upgU/ivi289pA1rrDiv3N8ghZXGho0PzlDI7yJ5wJw6JdC+VUV1YsakHYNOuy2GM4Z6WMAvTmFytCok17ELuIS3cDUIxZkowRPUduaJfJKS4h35UeacOTd4i2xheLK4nxuy9FKvyuz4VsWtyVZKsjZJnsDCtnwQ1RHe5dKLSvR6/kem1jaP0x7c5vtYLkAzkKrXM58hwrgumZoPqUnPADP6lUHsgKKVdkgo4Pak5/nmb7n8u5ORNYB5hhn7Mqs0m8y/Beo4MhIJX2ie4em81KPs/UvkT7lQjv05jK3Zv4reJckYvaO5DApV3Zwi6xa7FTupzNMYnXwfIFJfZB2Hl5TpO03JIP3gEfi/jE6jkDNyy//bP73hGYnCLmXYkLf6Zrt98E5dyA8rzd9F/Z5UC7cBIOjyWkDrrtDYAAU5YESJxf36AoB9yp8GQjDIRbSINbvb916O/OMmZeeWI5QEvS70bPkj6fmphnAwnRoRfLKiwIAMO0y/S/9pKkHcbXv3icoaCk8LuBA/Rarkkg6sSzlWMla/Wa50xjw/AYbuWYfOQIzrgLGF1SPrNpJTb2FCTFuLFCG7JM2/R/4QZXfKcYdamTseWO35Et5z5VSVrAb/joFfAK/R8ywcu4jk0YEsteLWnBA2szdzCpbEij3ffyRPhmoNAgQO8uVnu0UkkwWM1KF5h7pTEtkBv6oUADd/DobVyqlBM/63Wg/FeY3XGlOvQ9HjGC1pC9xonINIbEF6FNGvyBvE2njyDg==
hii i have seen the documentation , but i cant find any written code , just concepts,
could you help me, as i am trying to learn the library and i need to visualize the product code in order to understand what i am doing
thanks in advance
On 17 April 2018 at 08:20, Andreas Fabri <> wrote:
For 2D you have a whole chapter on visualization
https://doc.cgal.org/latest/GraphicsView/index.html#Chapter_CGAL_and_the_Qt_Graphics_View_Framework
For 3D there is the CGAL/demo/Polyhedron, but the internals
are not documented.
Best,
Andreas
On 4/16/2018 9:13 PM, hend helal wrote:
hii, i am new to cgal , and i want know how to visualize in cgal ,
there isn't any documentation of how to use the qt with cgal,
so is there any piece of code which describes using the qt with cgal in
order to visualize??
thanks in advance
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] visulization in cgal using qt, hend helal, 04/16/2018
- Re: [cgal-discuss] visulization in cgal using qt, Andreas Fabri, 04/17/2018
- Re: [cgal-discuss] visulization in cgal using qt, Hend Helal, 04/17/2018
