- To:
- Subject: [cgal-discuss] visualization in cgal
- Date: Thu, 26 Apr 2018 04:05:44 -0700 (MST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
i am new to cgal and i am really struggling to use this library, i have just
installed the library , but i am having difficulties using it and the
documentation of the library isnt really helpful. i am doing a project which
takes a point cloud file containing coordinates of a building and i need to
create a mesh of the building model,so could you tell me how to achieve
this.
also i have tried several codes from the documentation , but it doesnt
contain any code for the visualization as i need to visualize the result, i
know that there is qt, and opengl to visualize but i dont know how to use
it, so could you also help in this?
i would be really grateful for your help as i am really struggling
thanks in advance
- [cgal-discuss] visualization in cgal, hend helal, 04/26/2018
- Re: [cgal-discuss] visualization in cgal, Lokesh Kumar, 04/26/2018
