Re: [cgal-discuss] CGAL 4.12 Released, Computational Geometry Algorithms Library
- To:
- Subject: Re: [cgal-discuss] CGAL 4.12 Released, Computational Geometry Algorithms Library
- Date: Fri, 27 Apr 2018 08:20:27 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
On 25.04.2018 17:53, Laurent Rineau (CGAL/GeometryFactory) wrote:
> The CGAL Open Source Project is pleased to announce the release 4.12
> of CGAL, the Computational Geometry Algorithms Library.
Debian packages for CGAL 4.12 are now available as well. Simply add
deb http://debian.cgal.org stretch main
deb-src http://debian.cgal.org stretch main
deb http://debian.cgal.org buster main
deb-src http://debian.cgal.org buster main
to /etc/apt/sources.list (you only need the pair of lines corresponding
to the release you are using) and make sure that the package
apt-transport-https is installed. For sid, packages are available from
the official Debian repository. The packages are called libcgal13,
libcgal-dev, libcgal-qt5-13, libcgal-qt5-dev, libcgal-demo, and
libcgal-ipelets.
In case you want to download the packages manually, have a look at
http://debian.cgal.org/pool/main/c/cgal/ .
See also http://www.cgal.org/FAQ.html#debian_packages .
Joachim
- [cgal-discuss] CGAL 4.12 Released, Computational Geometry Algorithms Library, Laurent Rineau (CGAL/GeometryFactory), 04/25/2018
- Re: [cgal-discuss] CGAL 4.12 Released, Computational Geometry Algorithms Library, Laurent Rineau (CGAL/GeometryFactory), 04/26/2018
- Re: [cgal-discuss] CGAL 4.12 Released, Computational Geometry Algorithms Library, Joachim Reichel, 04/27/2018
