- To:
- Subject: [cgal-discuss] CGAL::cpp11::next(vb,ve)
- Date: Fri, 11 May 2018 01:23:39 -0700 (MST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
What does the below statement do?
*CGAL::cpp11::next(vb, 47)
where
typedef boost::graph_traits<Polyhedron>::vertex_iterator
vertex_iterartor
vertex_iterator vb;
Code:
https://doc.cgal.org/latest/Surface_mesh_deformation/Surface_mesh_deformation_2k_ring_roi_translate_rotate_example_8cpp-example.html
- [cgal-discuss] CGAL::cpp11::next(vb,ve), iampriyanshi, 05/11/2018
- Re: [cgal-discuss] CGAL::cpp11::next(vb,ve), Dinesh Shetty, 05/11/2018
