- To:
- Subject: Re: [cgal-discuss] CGAL::cpp11::next(vb,ve)
- Date: Fri, 11 May 2018 04:18:25 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
I guess advancing the iterator vb by 47
What does the below statement do?
*CGAL::cpp11::next(vb, 47)
where
typedef boost::graph_traits<Polyhedron>::vertex_iterator
vertex_iterartor
vertex_iterator vb;
Code:
https://doc.cgal.org/latest/Surface_mesh_deformation/Surface_mesh_deformation_2k_ring_roi_translate_rotate_example_8cpp-example.html
- [cgal-discuss] CGAL::cpp11::next(vb,ve), iampriyanshi, 05/11/2018
- Re: [cgal-discuss] CGAL::cpp11::next(vb,ve), Dinesh Shetty, 05/11/2018
