cgal-discuss - [cgal-discuss] How to test a CGAL Demo (Case Repair_polyhedron_plugin.cpp)
  • To:
  • Subject: [cgal-discuss] How to test a CGAL Demo (Case Repair_polyhedron_plugin.cpp)
  • Date: Wed, 30 May 2018 05:01:58 -0700 (MST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
Hi
After follow the manual CGAL installation:
https://www.cgal.org/download/windows.html#Boost
and compile everything ok I see the following files
C:\dev\CGAL-4.12\build\demo\Polyhedron>dir
30/05/2018 13:42 <DIR> .
30/05/2018 13:42 <DIR> ..
30/05/2018 13:29 32.323 ALL_BUILD.vcxproj
30/05/2018 13:29 287 ALL_BUILD.vcxproj.filters
30/05/2018 13:40 165 ALL_BUILD.vcxproj.user
30/05/2018 13:42 <DIR> CMakeFiles
30/05/2018 13:29 1.041 cmake_install.cmake
30/05/2018 13:42 <DIR> Debug
30/05/2018 13:29 12.583 INSTALL.vcxproj
30/05/2018 13:29 513 INSTALL.vcxproj.filters
30/05/2018 13:29 3.204 Polyhedron_Demo.sln
30/05/2018 13:40 <DIR> Release
30/05/2018 13:42 <DIR> Win32
30/05/2018 13:25 <DIR> __
7 archivos 50.116 bytes
7 dirs 102.536.847.360 bytes libres
so I open visual studio and open Polyhedron_Demo.sln in order to generate
the exe of
https://github.com/CGAL/cgal/blob/master/Polyhedron/demo/Polyhedron/Plugins/PMP/Repair_polyhedron_plugin.cpp
The problem is that the build is ok without any error but I don't see any
executable.
So how i can test this demo?
