- To:
- Subject: Re: [cgal-discuss] How to test a CGAL Demo (Case Repair_polyhedron_plugin.cpp)
- Date: Thu, 31 May 2018 10:05:53 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
I have installed Qt with qt-opensource-windows-x86-5.11.0.exe and I enabled QtScript during installation Andreas On 5/30/2018 6:15 PM, sergio campo
wrote:
Hello Andreas,
You right. After setting the right configuration:
WITH_QGLViewer:BOOL=ON WITH_DEMOS:BOOL= ON WITH_CGAL_Qt5:BOOL=ON The result of configuring demo/Polyhedron "NOTICE: This demo requires Qt5, and will not be compiled." See the results: -- Configuring demo in demo/Polyhedron Multi-configuration CMake generator: cannot display flags Requested component: Qt5 Requested component: ImageIO Requested component: MPFR Requested component: GMP Could NOT find Eigen3 (missing: EIGEN3_INCLUDE_DIR) (Required is at least version "3.2.0") ERROR: Intel TBB NOT found! Please define the TBBROOT (or TBB_INSTALL_DIR) and/or TBB_ARCH_PLATFORM environment variables. Looked for Threading Building Blocks in C:/Program Files/Intel/TBB;C:/Program Files (x86)/Intel/TBB NOTICE: Intel TBB was not found. Bilateral smoothing and WLOP plugins are faster if TBB is linked. ERROR: Intel TBB NOT found! Please define the TBBROOT (or TBB_INSTALL_DIR) and/or TBB_ARCH_PLATFORM environment variables. Looked for Threading Building Blocks in C:/Program Files/Intel/TBB;C:/Program Files (x86)/Intel/TBB NOTICE: This demo requires Qt5, and will not be compiled. The problem is that in qt5 is deprecated QtScrip (see https://doc.qt.io/archives/qt-5.10/qtmodules.html)and cmake does not found it. //The directory containing a CMake configuration file for Qt5ScriptTools. Qt5ScriptTools_DIR:PATH=Qt5ScriptTools_DIR-NOTFOUND //The directory containing a CMake configuration file for Qt5Script. Qt5Script_DIR:PATH=Qt5Script_DIR-NOTFOUND The other modules are successful linked: //The directory containing a CMake configuration file for Qt5Core. Qt5Core_DIR:PATH=C:/dev/Qt/5.11.0/msvc2015/lib/cmake/Qt5Core //The directory containing a CMake configuration file for Qt5Gui. Qt5Gui_DIR:PATH=C:/dev/Qt/5.11.0/msvc2015/lib/cmake/Qt5Gui //The directory containing a CMake configuration file for Qt5Help. Qt5Help_DIR:PATH=C:/dev/Qt/5.11.0/msvc2015/lib/cmake/Qt5Help //The directory containing a CMake configuration file for Qt5OpenGL. Qt5OpenGL_DIR:PATH=C:/dev/Qt/5.11.0/msvc2015/lib/cmake/Qt5OpenGL //The directory containing a CMake configuration file for Qt5ScriptTools. Qt5ScriptTools_DIR:PATH=Qt5ScriptTools_DIR-NOTFOUND //The directory containing a CMake configuration file for Qt5Script. Qt5Script_DIR:PATH=Qt5Script_DIR-NOTFOUND //The directory containing a CMake configuration file for Qt5Sql. Qt5Sql_DIR:PATH=C:/dev/Qt/5.11.0/msvc2015/lib/cmake/Qt5Sql //The directory containing a CMake configuration file for Qt5Svg. Qt5Svg_DIR:PATH=C:/dev/Qt/5.11.0/msvc2015/lib/cmake/Qt5Svg //The directory containing a CMake configuration file for Qt5Widgets. Qt5Widgets_DIR:PATH=C:/dev/Qt/5.11.0/msvc2015/lib/cmake/Qt5Widgets //The directory containing a CMake configuration file for Qt5Xml. Qt5Xml_DIR:PATH=C:/dev/Qt/5.11.0/msvc2015/lib/cmake/Qt5Xml //The directory containing a CMake configuration file for Qt5. Qt5_DIR:PATH=C:/dev/Qt/5.11.0/msvc2015/lib/cmake/Qt5 I added again the MakeFiles with correct values. Any suggestion? Best regards, Sergio On Wed, May 30, 2018 at 2:55 PM, sergio
campo <>
wrote:
Hello Andreas,
Thanks for your answer. Added cmake log file and I
don't see anything. I have qt and QGLViewer.
Best regards,
Ruben
On Wed, May 30, 2018 at 2:07
PM, Andreas Fabri <>
wrote:
My guess is that there is no executable because you do not have Qt or Qglviewer installed. You should see that in the log of cmake. andreas On 5/30/2018 2:01 PM, sergio wrote: Hi After follow the manual CGAL installation: https://www.cgal.org/download/windows.html#Boost and compile everything ok I see the following files C:\dev\CGAL-4.12\build\demo\Polyhedron>dir 30/05/2018 13:42 <DIR> . 30/05/2018 13:42 <DIR> .. 30/05/2018 13:29 32.323 ALL_BUILD.vcxproj 30/05/2018 13:29 287 ALL_BUILD.vcxproj.filters 30/05/2018 13:40 165 ALL_BUILD.vcxproj.user 30/05/2018 13:42 <DIR> CMakeFiles 30/05/2018 13:29 1.041 cmake_install.cmake 30/05/2018 13:42 <DIR> Debug 30/05/2018 13:29 12.583 INSTALL.vcxproj 30/05/2018 13:29 513 INSTALL.vcxproj.filters 30/05/2018 13:29 3.204 Polyhedron_Demo.sln 30/05/2018 13:40 <DIR> Release 30/05/2018 13:42 <DIR> Win32 30/05/2018 13:25 <DIR> __ 7 archivos 50.116 bytes 7 dirs 102.536.847.360 bytes libres so I open visual studio and open Polyhedron_Demo.sln in order to generate the exe of https://github.com/CGAL/cgal/blob/master/Polyhedron/demo/Polyhedron/Plugins/PMP/Repair_polyhedron_plugin.cpp The problem is that the build is ok without any error but I don't see any executable. So how i can test this demo? -- Sent from: http://cgal-discuss.949826.n4.nabble.com/ -- Andreas Fabri, PhD Chief Officer, GeometryFactory Editor, The CGAL Project phone: +33.492.954.912 skype: andreas.fabri -- Andreas Fabri, PhD Chief Officer, GeometryFactory Editor, The CGAL Project phone: +33.492.954.912 skype: andreas.fabri |
- [cgal-discuss] How to test a CGAL Demo (Case Repair_polyhedron_plugin.cpp), sergio, 05/30/2018
- Message not available
- Re: [cgal-discuss] How to test a CGAL Demo (Case Repair_polyhedron_plugin.cpp), Andreas Fabri, 05/31/2018
- Re: [cgal-discuss] How to test a CGAL Demo (Case Repair_polyhedron_plugin.cpp), sergio campo, 05/31/2018
