- To:
- Subject: [cgal-discuss] Moving Points in 2D(Kinetic Voronoi)
- Date: Mon, 4 Jun 2018 01:15:21 -0700 (MST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
Hello people. I am new to cgal and I need to create a project where I have
moving points in 2D, where the trajectories of points can change at some
time. What I have to do is to create the kinetic voronoi and send
notification when two points approach very close to each other. I know that
there is a kinetic framework in CGAL but I can't understand how to work with
it and how to send notification when two points are very close. Can anyone
help me with that framework or suggest me any other way to create it ?
Thank you in advance !
- [cgal-discuss] Moving Points in 2D(Kinetic Voronoi), Hepic, 06/04/2018
