cgal-discuss - Re: [cgal-discuss] Intersections of the segment and isosurface
  • To:
  • Subject: Re: [cgal-discuss] Intersections of the segment and isosurface
  • Date: Mon, 4 Jun 2018 05:40:03 -0700 (MST)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
  • Ironport-phdr: 9a23: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
Well , thank you, Shankar^_^
In my program the computation of the intersections between the segment and
isosurface is implemented by myself. May be at last I have to re-implement
such a function based on the exact kernels, Yet I am wondering if the CGAL
library has some function or some example to show how to compute the
intersections of the segment and isosurface of voxels robustly. That will be
more perfect^_^
