- To:
- Subject: [cgal-discuss] Surface Mesh Subdivision over a local area
- Date: Mon, 4 Jun 2018 12:08:32 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hello,
I have a polyhedron defined as a Polyhedron/Surface_Mesh object.
I'd like to subdivide a specific location of the mesh to have a higher resolution.
It seems the functions operate over the whole mesh rather than a specific area?
Is there a method to define a smaller area, in terms of ids, vertex locations or some other method?
Thank you
Shankar
- [cgal-discuss] Surface Mesh Subdivision over a local area, Shankar Kulumani, 06/04/2018
- Re: [cgal-discuss] Surface Mesh Subdivision over a local area, Sebastien Loriot (GeometryFactory), 06/04/2018
- Re: [cgal-discuss] Surface Mesh Subdivision over a local area, Shankar Kulumani, 06/04/2018
