cgal-discuss - Re: [cgal-discuss] Surface Mesh Subdivision over a local area
  • To:
  • Subject: Re: [cgal-discuss] Surface Mesh Subdivision over a local area
  • Date: Mon, 4 Jun 2018 13:05:34 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
If you are only interested in refining, maybe isotropic_remeshing
is the way to go:
That's a great suggestion. Thank you. I'll need to look at it and get it implemented.
On Mon, Jun 4, 2018 at 12:30 PM Sebastien Loriot (GeometryFactory) <> wrote:
The "simplest" solution I see is to extract the portion of the mesh
you want to refine and call subdivision on it then you can try to
re-plugin it in the original mesh (after having removed the faces).
It will imply subdividing removed patch boundary to make them match.
is the way to go:
https://doc.cgal.org/latest/Polygon_mesh_processing/group__PMP__meshing__grp.html#gad3d03890515ae8103bd32a30a3486412
Sebastien.
On 06/04/2018 06:08 PM, Shankar Kulumani wrote:
> Hello,
> I have a polyhedron defined as a Polyhedron/Surface_Mesh object.
> I'd like to subdivide a specific location of the mesh to have a higher
> resolution.
> It seems the functions operate over the whole mesh rather than a
> specific area?
> Is there a method to define a smaller area, in terms of ids, vertex
> locations or some other method?
> Thank you
> Shankar
