- To:
- Subject: [cgal-discuss] Using PMP Mesh Processing with Polyhedron type.
- Date: Mon, 4 Jun 2018 22:28:18 +0530
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hello,
I have a Polyhedron *m_pPolyhedron;
I want to use it to run on it various Polygon_mesh_processing algorithm on it.
For instance, I want to run isotropic_remeshing();
The example of isotropic_remeshing Here uses Surface_mesh.
Can anyone share code snippet in order to do so? So that I could run various PMP algorithms on Polyhedron type.
Thanks
Sukhraj Singh
- [cgal-discuss] Using PMP Mesh Processing with Polyhedron type., Sukhraj Singh, 06/04/2018
- Re: [cgal-discuss] Using PMP Mesh Processing with Polyhedron type., Shankar Kulumani, 06/04/2018
- Re: [cgal-discuss] Using PMP Mesh Processing with Polyhedron type., Sukhraj Singh, 06/04/2018
- Re: [cgal-discuss] Using PMP Mesh Processing with Polyhedron type., Sukhraj Singh, 06/05/2018
