- To:
- Subject: [cgal-discuss] OpenMP use with Surface mesh
- Date: Thu, 7 Jun 2018 06:58:50 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:z9wRzR2wiw7e/oQAsmDT+DRfVm0co7zxezQtwd8Zse0WKfad9pjvdHbS+e9qxAeQG9mDtrQc06L/iOPJYSQ4+5GPsXQPItRndiQuroEopTEmG9OPEkbhLfTnPGQQFcVGU0J5rTngaRAGUMnxaEfPrXKs8DUcBgvwNRZvJuTyB4Xek9m72/q99pHPYwhEniaxba9vJxiqsAvdsdUbj5F/Iagr0BvJpXVIe+VSxWx2IF+Yggjx6MSt8pN96ipco/0u+dJOXqX8ZKQ4UKdXDC86PGAv5c3krgfMQA2S7XYBSGoWkx5IAw/Y7BHmW5r6ryX3uvZh1CScIMb7S60/Vza/4KdxUBLnhycJOTA6/m/KlMJ/kLlWrwi9qxFl2YPYfJ2ZOfh4c6jAfd0aX21BXsNJWiJcAoOzdY0PD+kbMuZCsoLzokYOrR+jBQmpHuzvzD5IjWLx0K0h0+QuCwfG3A87H94Us3TZt9r1NKIIXuC0yKnE1ynMb/RT2Trk7oXDbxMvoemUUL5ubcbczVMjGgDFg1mKt4DpIjyY2v4CvmSG6edrSPihhHQ9qw5rpzii3scshZfNhoIS0l3E8D92wIcxJdGhSU57fcKoHIJetyyVKod6WMwiQ2ZvuCY1zr0Jp4S3czQNyJQi3xLfavqHfJaU4h/7SuqdPTN1iGhmdb+/nRq+71Wsx+LmWsS7zVpGti9FncPNtnAJ2RzT8M+HSv5l80e62TaAzQbT6uJfIUwulqrWMJEhwrsqmZoStUTPBDP5mELzjKOObEUr5vCo6/j7YrXhvpKTK4B0hRv6Mqg3h8O/AP84PRQTX2iA4uSxz6bj/E38QLVSlPI6iKjZsJbAJcQavKG1GQFV0pxwoyq4Wjyp2dBdkXgcJ09eYzqGiZLoMhfAOqPWF/C61m+smTFozuqOHaDlH5DEKHmLxKzhdLB+8Ahf4AU2xNFboZlTD+dSc7rIRkbtuYmAXVcCOAuuzrO/UYQv5sYlQWuKR5ShHubXuF6M6PgoJrDVNoAQsTf5bfMi4qy31CNrqRomZaCsmKAvRjWgBP0/eheWZHPthpEKFmJY5lNjHtyvs0WLVHtoX1j3X6844WtmWoevDIOGR5z1xbLdhWG0GZpZYm0AAVeJQy/l
Hello
I'm computing many properties over the elements of a surface mesh, all edges, half edges and faces.
Currently this is done using the respective edges, face, halfedge iterator ranges.
Once calculated the properties are stored as properties within the surface mesh.
Is it possible to iterate through these elements using a parallel loop, i.e. OpenMP parallel for?
I'm of course just going to try but was wondering if there are any issues to be aware of or things to consider.
Thank you for the great project.
- [cgal-discuss] OpenMP use with Surface mesh, Shankar Kulumani, 06/07/2018
- Re: [cgal-discuss] OpenMP use with Surface mesh, Sebastien Loriot (GeometryFactory), 06/07/2018
- Re: [cgal-discuss] OpenMP use with Surface mesh, Shankar Kulumani, 06/07/2018
