- To:
- Subject: Re: [cgal-discuss] How to convert from stl format to off forma and vice versa?
- Date: Thu, 7 Jun 2018 00:00:33 -0700 (MST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
I found in the following discussion that exist CGAL implementations for stl
files:
http://cgal-discuss.949826.n4.nabble.com/Support-for-stl-files-tp4663235.html
#include <CGAL/IO/STL_reader.h>
#include <CGAL/IO/STL_writer.h>
Thanks you,
Sergio
- [cgal-discuss] How to convert from stl to off and off to stl?, sergio, 06/06/2018
- Re: [cgal-discuss] How to convert from stl to off and off to stl?, Sukhraj Singh, 06/06/2018
- Re: [cgal-discuss] How to convert from stl to off and off to stl?, Shankar Kulumani, 06/06/2018
- Re: [cgal-discuss] How to convert from stl to off and off to stl?, Bruno Levy, 06/06/2018
- Re: [cgal-discuss] How to convert from stl format to off forma and vice versa?, sergio, 06/07/2018
