Re: [cgal-discuss] How to calculate the intersection volume between two hyper-ellipsoids
- To:
- Subject: Re: [cgal-discuss] How to calculate the intersection volume between two hyper-ellipsoids
- Date: Fri, 8 Jun 2018 09:31:02 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
Sorry, but that is not available. Andreas On 6/8/2018 6:28 AM, hrbspider wrote:
Hello, I have constructed two hyper-ellipsoids from a point set in 5-d space using Approximate_min_ellipsoid_d, but how to do some operation on these hyper-ellipsoids, such as compute the intersection volume between two hyper-ellipsoids? Is there any function in CGAL? Thank you. -- Sent from: http://cgal-discuss.949826.n4.nabble.com/ -- Andreas Fabri, PhD Chief Officer, GeometryFactory Editor, The CGAL Project phone: +33.492.954.912 skype: andreas.fabri |
- [cgal-discuss] How to calculate the intersection volume between two hyper-ellipsoids, hrbspider, 06/08/2018
- Re: [cgal-discuss] How to calculate the intersection volume between two hyper-ellipsoids, Andreas Fabri, 06/08/2018
- Re: [cgal-discuss] How to calculate the intersection volume between two hyper-ellipsoids, hrbspider, 06/10/2018
