- To:
- Subject: [cgal-discuss] CGAL : centroid and BigFLoat
- Date: Fri, 8 Jun 2018 11:38:28 +0200
Hello, I have some trouble using the CORE::BigFloat number type with the centroid function of CGAL, and I did not see any body with the same problems. Here is a minimal example that does not compile for me : #include <CGAL/CORE_BigFloat.h> I have the following error :
I can solve this by simply turning the unsigned nb_points into an int, but there is may be something I did not see, or the problem is solved in a more recent version of CGAL ? My environment is : Compiler : GNU 6.3.1, /usr/lib64/ccache/c++ OS : Fedora 25 CGAL : 4.9.1 installed with dnf Thanks ! Tom.
- [cgal-discuss] CGAL : centroid and BigFLoat, Tom Dreyfus, 06/08/2018
- Re: [cgal-discuss] CGAL : centroid and BigFLoat, Sebastien Loriot (GeometryFactory), 06/12/2018
