cgal-discuss - Re: [cgal-discuss] Segment Intersection to form cell decomposition
  • To:
  • Subject: Re: [cgal-discuss] Segment Intersection to form cell decomposition
  • Date: Tue, 12 Jun 2018 20:06:19 -0700 (MST)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
Is there anyway to extract the vertices (in order clockwise or counter
clockwise) for each of the holes (cells)? I have tried the code with five
segments (as given in the code sample) and it just produce only one hole (As
I imagine, it should produce ~ 7 holes in total).
For example, I insert an image here for better explanation about my problem,
could you suggest the way to get the vertices & edges for each bounded faces
(e.g., F1, F2,F3,F4) which formed by intersecting the line Segments (1, 2,
...,6)
Thank you.
<http://cgal-discuss.949826.n4.nabble.com/file/t375966/cell_decomposition.jpg>
