cgal-discuss - [cgal-discuss] Segment Intersection to form cell decomposition
  • To:
  • Subject: [cgal-discuss] Segment Intersection to form cell decomposition
  • Date: Mon, 11 Jun 2018 07:15:40 -0700 (MST)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
HI,
Could you please give a suggestion for the task that:
- I have a list of line segments. I need to find out faces (cells) generated
by intersecting the segments. Could you suggest me which functions should I
use to implement the cell decomposition by intersecting lines and get
information of the cells (faces, vertices, edges) .
- Is it possible to achieve adjacent relation between cells (for instance,
cells i is in adjacent (neighbour) with ceill j,k, m etc)?
Could you please suggest which package and function should I use to complete
this task? I am new to CGAL. Thank you so much. I appreciate any comment &
suggestion.
Best regards,
Anne
