- To:
- Subject: [cgal-discuss] Point Property map
- Date: Fri, 6 Jul 2018 11:21:09 -0700 (MST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
Hi, I would like to create a pointPropertyMap for the
CGAL::segmentation_via_sdf_values function. How can I do it?
Cheer,
Annie-Pier
- [cgal-discuss] Point Property map, Annie-Pier L., 07/06/2018
- Re: [cgal-discuss] Point Property map, Sebastien Loriot (GeometryFactory), 07/09/2018
- Re: [cgal-discuss] Point Property map, Annie-Pier L., 07/09/2018
