RE: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results
- To: "" <>
- Subject: RE: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results
- Date: Tue, 10 Jul 2018 09:41:25 +0000
- Accept-language: fr-FR, en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=PermError ; spf=Pass
- Ironport-phdr: 9a23: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
- Spamdiagnosticmetadata: NSPM
- Spamdiagnosticoutput: 1:99
Hello,
I took a closer look, our CMakeLists clones "releases/CGAL-4.10".
Therefore, the bug only no longer exists - except in my environment :(
Thanks for the responsiveness and the help.
Best.
Kilian Demeulemeester
Directeur R&D
Snapkin | Outil de mesure et de mise en plan 2D/3D pour le bâtiment.
Tél : +33 (0)7 83 49 82 36 | Discutons !
-----Message d'origine-----
De :
De la part de Simon Giraudot
Envoyé : mardi 10 juillet 2018 11:00
À :
Objet : Re: [cgal-discuss] Point Set Shape Detection - connected component do
Hello,
Are you sure you are using CGAL 4.10.2?
This bug has indeed existed but it was fixed in CGAL 4.10.1:
https://github.com/CGAL/cgal/pull/2194
Best,
Simon Giraudot, PhD
R&D Engineer
GeometryFactory - http://geometryfactory.com/
Le 10/07/2018 à 10:10, Kilian Demeulemeester a écrit :
> Good morning,
> I managed to identify the bug in the RANSAC class. It can be described in
> this way:
> During the detect method, the process is as follows:
> 1. Candidates are generated
> 2. Among the generated candidates, the best of them is extracted:
> best_candidate - that we will name SHAPE1
> 3. The connected_components method is called on SHAPE1, and the value of
> m_has_connected_component changes to true.
> 4. For the bug to occur, we assume that SHAPE1 meets the minimum number of
> inliers condition BUT the stop_probability associated with SHAPE1 is not
> sufficient for it to be extracted.
> 5. From then on, the loop starts again at step 1.
> 6. After studying more candidates, SHAPE1 is again the best candidate.
> 7. HOWEVER, during the call of score method, THE VALUE OF SHAPE1 m_indices
> HAS BEEN MODIFIED.
> 8. As in step (3), the connected_components method is called on SHAPE1.
> However, since m_has_connected_component is already a true, the value of
> m_indices IS NOT MODIFIED. Therefore, the largest connected_component is
> not extracted.
> 9. As in step 4, the stop_proability value associated with SHAPE1 is
> calculated. Let's just say this time it's enough to extract the candidate.
> Then, the inliers are extracted. Unfortunately, these do not correspond to
> good inliers.
> My idea is to fix the score method as so: when this method is called, the
> value of m_has_connected_component should be set to false BECAUSE IT
> CHANGES THE value of m_indices.
> In order to fix the bug locally (monkey patching), I've override the
> connected_component method so that it keeps m_has_connected_component to
> false. By doing so, the bug was fixed.
> If my description seems clear, can I open a merge request to correct the
> `score` method? It would be for me the opportunity to contribute (in a tiny
> way) to the project :)
> Best.
> Directeur R&D
> De : Kilian Demeulemeester
> Envoyé : lundi 9 juillet 2018 15:17
> À :
> Objet : RE: [cgal-discuss] Point Set Shape Detection - connected component
> Hello,
> The following snippet proves the bug (in my environment):
> https://gitlab.com/snippets/1731486
> The part about loading the point cloud and writing down the point cloud
> have to be rewritten (because I'm using my company custom library).
> The code provided in the snippet detects 343 shapes - most of them being
> not "connected".
> Best.
> De :
> De la part de Kilian Demeulemeester Envoyé : lundi 9 juillet 2018 11:44 À
> I'll try to create a snippet.
> The bugs occur with the parameters I've provided:
> - probability=0.01
> - minPoints=10000
> - epsilon=0.01
> - clusterEpsilon=0.05
> - normalThreshold=0.9
> It looks that the parameter minPoints is the one responsible for this
> behavior.
> When using the default value, the extracted shapes are correct (but a lot
> of them are missing).
> Best.
> Bien cordialement.
> Directeur R&D
> De :
> De la part de Simon Giraudot Envoyé : lundi 9 juillet 2018 10:53 À :
> Hello,
> I am sorry but I cannot reproduce your bug. Does it happen all the time?
> RANSAC being based on randomness, it's possible that the result changes
> from one run to another. Do you have the (x,y,z) coordinates of where this
> bug happens?
> Also, there are no normal vectors in the file you provide. Can you tell me
> how you estimate these normals? Better, can you share the source code of
> how you estimate the normals + call RANSAC (maybe just the section of the
> code if it is part of a larger project)? That way, I am sure I'm doing the
> same thing.
> Best,
> Simon Giraudot, PhD
> R&D Engineer
> Le 09/07/2018 à 10:02, Kilian Demeulemeester a écrit :
>> Hello,
>> Here is the point cloud in PLY format:
>> https://drive.google.com/file/d/1cPcxFLQCccmd2X1OWzunc0WtRIiuM9f0/view
>> ?usp=sharing
>> Best,
>> Bien cordialement.
>> Directeur R&D
>> De :
>> De
>> la part de Simon Giraudot Envoyé : lundi 9 juillet 2018 09:27 À :
>> Hello,
>> Le 06/07/2018 à 15:33, Kilian Demeulemeester a écrit :
>>> The point cloud is available here:
>>> https://drive.google.com/open?id=1r4-9vLq35L6c4SwlGvqppzv6-wrP8nfV
>>> (108Mo).
>> I can't seem to open E57 files, could you convert your point cloud to
>> another format? (PLY, OFF, LAS, XYZ.)
>> Thank you,
>> Simon Giraudot, PhD
>> R&D Engineer
>>> We are using CGAL 4.10.2.
>>> I've seen that there has been changes relative to that package but...
>>> nothing related to this.
>>> I've checked the release note and didn't see anything related to that bug.
>>> I've also blamed the changes of the method connected_component in
>>> CGAL\Shape_detection_3\Shape_base.h - and did not find any changes lately.
>>> As for now, I think I will try to extend the class
>>> CGAL::Shape_detection_3::Plane<Traits> to create my own version - and
>>> overload the connected_component method to use our own version (using
>>> opencv).
>>> Bien cordialement.
>>> Directeur R&D
>>> De :
>>> De
>>> la part de Simon Giraudot Envoyé : vendredi 6 juillet 2018 15:04 À :
>>> Hello,
>>> This is indeed unexpected. From what you explain in your email, I don't
>>> think you did anything wrong, so I suspect there is a bug in the package.
>>> What version of CGAL do you use? There has been some changes in the Shape
>>> Detection package lately (but if I remember correctly, nothing that
>>> addresses a bug like this one).
>>> Is there any way you could you share the point cloud so I can try to
>>> reproduce it and find where is the bug?
>>> Best,
>>> Simon Giraudot, PhD
>>> R&D Engineer
>>> Le 06/07/2018 à 10:16, KDemeul a écrit :
>>>> Hello,
>>>> I am trying to use the Point Set Shape Detection
>>>> <https://doc.cgal.org/latest/Point_set_shape_detection_3/index.html#
>>>> Chapter_Point_Set_Shape_Detection>
>>>> package - in order to detect PLANEs only.
>>>> I've defined the value of the parameters as follow:
>>>> -probability=0.01
>>>> - minPoints=10000
>>>> - epsilon=0.01
>>>> However, it seems that the clusterEpsilon parameter is not correctly
>>>> taken into account.
>>>> Here is an example of a plane detected by the algorithm.
>>>> As one can see, the left part is disconnected from the right part -
>>>> by a gap of approx 1.6m.
>>>> <http://cgal-discuss.949826.n4.nabble.com/file/t375977/Sans_titre.pn
>>>> g>
>>>> Is there something I don't get?
>>>> Best regards,
>>>> Kilian Demeulemeester.
>>>> Sent from: http://cgal-discuss.949826.n4.nabble.com/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
- [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, KDemeul, 07/06/2018
- Re: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, Simon Giraudot, 07/06/2018
- RE: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, Kilian Demeulemeester, 07/06/2018
- Re: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, Simon Giraudot, 07/09/2018
- RE: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, Kilian Demeulemeester, 07/09/2018
- RE: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, Kilian Demeulemeester, 07/10/2018
- Re: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, Simon Giraudot, 07/10/2018
