cgal-discuss - [cgal-discuss] How to store instances of external class via pointer in 2d geometries
  • To:
  • Subject: [cgal-discuss] How to store instances of external class via pointer in 2d geometries
  • Date: Thu, 12 Jul 2018 16:35:43 -0700 (MST)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=Pass
  • Ironport-phdr: 9a23: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
I have objects which are represented via
CGAL::Arr_segment_traits_2<kernel>::Curve_2 and later other 2D geometries. I
use arrengements with history to find intersections between these objects
but in order to do that I would need to store a pointer to the instances in
these 2d geometries.
I'm not quite sure what cgal object I need to inherit from and what other
changes I need to do.
Thanks
