Re: [cgal-discuss] How to store instances of external class via pointer in 2d geometries
- To:
- Subject: Re: [cgal-discuss] How to store instances of external class via pointer in 2d geometries
- Date: Sat, 14 Jul 2018 04:53:04 -0700 (MST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=Pass
- Ironport-phdr: 9a23:yCpTHB2lh0jKbshXsmDT+DRfVm0co7zxezQtwd8Zse0TK/ad9pjvdHbS+e9qxAeQG9mDtbQc06L/iOPJYSQ4+5GPsXQPItRndiQuroEopTEmG9OPEkbhLfTnPGQQFcVGU0J5rTngaRAGUMnxaEfPrXKs8DUcBgvwNRZvJuTyB4Xek9m72/q99pHPYghEniaxba9vJxiqsAvdsdUbj5F/Iagr0BvJpXVIe+VSxWx2IF+Yggjx6MSt8pN96ipco/0u+dJOXqX8ZKQ4UKdXDC86PGAv5c3krgfMQA2S7XYBSGoWkx5IAw/Y7BHmW5r6ryX3uvZh1CScIMb7S60/Vza/4KdxUBLmhicJOSA6/m7VhMx+ka1Urw6uqRFk347ZYp2ZOOZicq/BY98XQ3dKUMZLVyxGB4Oxd5AAD/AbMuZZqYn9vF8OrQalBQmsGejizSRHiWHw3a080+UsCgHG3As6H9IUt3TUts71O7kIUeCrzanH0SvMY+lL1jjj8YXFdA0qr/+LXbJ1a8XRyE8vGhvDjlqKsoPqJDeV2foXv2eH6OpgUPqji28hqwFrozig3N0giofTho8T11vK9j15zZ4oKdC5VkJ3e8CoHZteui2AKod7TM0vT3tqtSokzLANpIS1czIQyJs9wh7Sc/yHfJaM4hLkTOuRJzh1iGhjeL2lnBm96kygxfPmWsao11ZKqzJJktjKtn8Tyxze8tWLR/pj8ku7xzqC1w7e5vtZLU06m6fXMZwszqAompoWq0vDHyv2mEvsjK+Rc0Up4vOn5PrhYrXgpp6RLI90igbkMqQ0ncy/G/84PRYUX2iF+OSzyKPs8VfkT7pUlvE2iLXWsIjGJcQHoa60GxNa0ok55Ba7FjupzdUYnWIbI1JYYxKHlJPkO0rOIfD9FfewmU6gkDZtx/DcP73uGI/BLnbZkOSpQbEo4EFVzE8/zMtU+olPIrAHOvP6HEHr5/LCCRpsORa9wuD8DMhm1stKU2+JBL6xMKTIq1iS/e81PeiHackZtWCueLAe+/fygCphyhcmdq6z0M5PMSHqLrFdO0ycJEHUrJIEGGYOsBA5SbW62l2FSyRUfW2/Rbw97Tx9BI/0Vd6fFLDou6SI2WKAJrMTfnpPUwDeEXDybYKeQPoWdiOZL4ltn25cDOXze8oazRir8TTC5f9nI+7To3BKs86l0tF/7ene0xo18G4tAg==
Nvm I found an easy solution.
One can make use of the Arr_curve_data_traits_2 traits.
http://www-sop.inria.fr/members/Clement.Jamin/CGAL/Td_doc_r3/Arrangement_on_surface_2/classCGAL_1_1Arr__curve__data__traits__2.html
- [cgal-discuss] How to store instances of external class via pointer in 2d geometries, brainslush, 07/13/2018
- Re: [cgal-discuss] How to store instances of external class via pointer in 2d geometries, brainslush, 07/14/2018
