Re: [cgal-discuss] remove_self_intersections changes the mesh and the reparation is less when it is build in Release than when i build my application in Debug
- To:
- Subject: Re: [cgal-discuss] remove_self_intersections changes the mesh and the reparation is less when it is build in Release than when i build my application in Debug
- Date: Sun, 15 Jul 2018 16:46:10 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hi Sergio,
I tried it for you - remove_self_intersection can't fix it. There is
still numerous intersections left.
Also FYI, MeshFix can't fix it either - the output mesh is virtually
empty with only a simple convex.
Best,
Zesen
On Tue, Jul 10, 2018 at 11:42 AM, sergio campo
wrote:
> Hello Sebastien,
> Could you please let me know if you can fix this complex file?
> https://drive.google.com/open?id=1BVs6x_VGx1RMGxC1BcGf_PCe-kLoTJBc
> I tried but it does not fixed it has 104106 intersected face of 104384 faces
> (99% of model)
> Thanks and best regards,
> Rubén
> On Tue, Jul 10, 2018 at 5:34 PM, Sebastien Loriot (GeometryFactory)
> wrote:
>> I never used MeshFix as I don't think there is a linux version.
>> If you have some hard to fix self-intersections I'm interested in
>> having a look and I'll let you know if CGAL can fix those.
>> You can send me the file off list if you don't want to spam the whole
>> list.
>> Thanks,
>> Sebastien.
>> On 07/10/2018 12:12 PM, Zesen Qian wrote:
>>> sorry, not try to hijack the thread, but how is this self-intersection
>>> fix method compared to MeshFix? I'm using the latter and it can't fix
>>> meshes with SI that's too complex.
>>> Best,
>>> Zesen
>>> On Mon, Jul 9, 2018 at 5:43 AM, Sebastien Loriot (GeometryFactory)
>>> wrote:
>>>> No on linux. The precompiled demo on windows is available here:
>>>> https://www.cgal.org/demo/4.12/polyhedron_3.zip
>>>> with common dlls (to be put in the same directy as Polyhedron_3.exe
>>>> in the aforementioned archive):
>>>> https://www.cgal.org/demo/4.12/CGAL-demoDLLs.zip
>>>> Sebastien.
>>>> On 07/09/2018 11:40 AM, sergio campo wrote:
>>>>> Thanks for your fast answer! :). I set std::setprecision(17) with the
>>>>> same results. Have you execute the demo with Windows? In my case I
>>>>> executed
>>>>> the program in Windows 10.
>>>>> On Mon, Jul 9, 2018 at 10:27 AM, Sebastien Loriot (GeometryFactory)
>>>>> <mailto:>>
>>>>> wrote:
>>>>> No idea what you did, if I open the polyhedron demo, load your
>>>>> model
>>>>> call orient polygon soup and remove self intersections, everything
>>>>> is done in less than a minute on my computer and the output model
>>>>> does not
>>>>> contain any self-intersection.
>>>>> Do you have intermediate writing to "string" with a rounding of
>>>>> the
>>>>> coordinates of the point not using the max precision
>>>>> (std::setprecision(17) for the ostream)?
>>>>> Sebastien.
>>>>> On 07/04/2018 11:33 AM, sergio wrote:
>>>>> This is may application that i compile in windows in Release
>>>>> with the showed
>>>>> CMakeList.txt and cgal_vtk_test.cpp files. When I try to
>>>>> repair
>>>>> this file:
>>>>> Number intersection: 290
>>>>> https://drive.google.com/file/d/1uqcbZqgtbiiXYjKnzzb5d-OXm4JAHqdx/view?usp=sharing
>>>>> <https://drive.google.com/file/d/1uqcbZqgtbiiXYjKnzzb5d-OXm4JAHqdx/view?usp=sharing>
>>>>> 1. my application build in Release generate the following
>>>>> file:
>>>>> Number intersections: 179
>>>>> Add some visible holes and some deformations.
>>>>> Repairing time:..................201.128 seconds.
>>>>> https://drive.google.com/file/d/13Vfw0pP5Ymw0oo4RnfRjKTI_aTndb6P4/view?usp=sharing
>>>>> <https://drive.google.com/file/d/13Vfw0pP5Ymw0oo4RnfRjKTI_aTndb6P4/view?usp=sharing>
>>>>> 2. my application compiled in Debug, it generate the following
>>>>> file:
>>>>> Number intersections: 4
>>>>> Repairing time:..................1072.96 seconds.
>>>>> https://drive.google.com/file/d/1x1Z7qaNcnfGC8a24qzJI-DZEF3qqeLqq/view?usp=sharing
>>>>> <https://drive.google.com/file/d/1x1Z7qaNcnfGC8a24qzJI-DZEF3qqeLqq/view?usp=sharing>
>>>>> with warnings:
>>>>> Expression : !"Returning no output. Filling hole with extra
>>>>> triangles is not
>>>>> successful!"
>>>>> File :
>>>>> C:\dev\CGAL-4.12\include\CGAL/Polygon_mesh_processing/internal/Hole_filling/Triangulate_hole_polyline.h
>>>>> Line : 1103
>>>>> Explanation:
>>>>> Refer to the bug-reporting instructions at
>>>>> https://www.cgal.org/bug_report.html
>>>>> <https://www.cgal.org/bug_report.html>
>>>>> The problem is that in debug build it takes around 17 min for
>>>>> reparacion and
>>>>> in Release it only takes 3 minutes, but in relese build it
>>>>> modify the
>>>>> original mesh and add a big hole(pleas check links to files)
>>>>> What's wrong?
>>>>> CMakeList.txt
>>>>> cmake_minimum_required(VERSION 2.8.4)
>>>>> project( cgal_vtk_test )
>>>>> # Find CGAL
>>>>> find_package(CGAL REQUIRED COMPONENTS Core) # If the
>>>>> dependency
>>>>> is required,
>>>>> use REQUIRED option - if it's not found CMake will issue an
>>>>> error
>>>>> include( ${CGAL_USE_FILE} )
>>>>> # Find VTK
>>>>> find_package(VTK REQUIRED)
>>>>> include(${VTK_USE_FILE})
>>>>> # Setup your executable
>>>>> #include_directories (BEFORE "include")
>>>>> include( CGAL_CreateSingleSourceCGALProgram )
>>>>> create_single_source_cgal_program( "cgal_vtk_test.cpp" ) #
>>>>> This
>>>>> will create
>>>>> an executable target with name 'cgal_vtk_test'
>>>>> # Add VTK link libraries to your executable target
>>>>> target_link_libraries(cgal_vtk_test ${VTK_LIBRARIES})
>>>>> #target_link_libraries(cgal_vtk_test)
>>>>> cgal_vtk_test.cpp
>>>>> #include <fstream>
>>>>> #include <iomanip>
>>>>> #include <ctime>
>>>>> // CGAL
>>>>> #include <limits>
>>>>> #include <CGAL/Polygon_mesh_processing/repair.h>
>>>>> #include
>>>>> <CGAL/Polygon_mesh_processing/internal/repair_extra.h>
>>>>> #include <CGAL/Polygon_mesh_processing/corefinement.h>
>>>>> #include
>>>>> <CGAL/Polygon_mesh_processing/polygon_soup_to_polygon_mesh.h>
>>>>> #include <CGAL/Polyhedron_3.h>
>>>>> #include <CGAL/Surface_mesh/Surface_mesh.h>
>>>>> #include <CGAL/IO/print_wavefront.h>
>>>>> #include <CGAL/IO/OBJ_reader.h>
>>>>> #include <CGAL/assertions.h>
>>>>> #include <CGAL/IO/STL_reader.h>
>>>>> #include <CGAL/IO/STL_writer.h>
>>>>> typedef CGAL::Exact_predicates_inexact_constructions_kernel
>>>>> Kernel;
>>>>> typedef CGAL::Surface_mesh<Kernel::Point_3> Mesh;
>>>>> typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
>>>>> void addStringToFileName(std::string & fileName, const
>>>>> std::string & str)
>>>>> size_t lastindex = fileName.find_last_of(".");
>>>>> std::string name = fileName.substr(0, lastindex);
>>>>> fileName = name + str;
>>>>> bool repairOBJFile(std::string & fileName)
>>>>> clock_t begin = clock();
>>>>> std::cout << std::endl;
>>>>> std::cout <<
>>>>> << std::endl;
>>>>> std::cout << ". Repairing
>>>>> << std::endl;
>>>>> std::cout <<
>>>>> << std::endl;
>>>>> std::ifstream input(fileName);
>>>>> if (!input)
>>>>> std::cerr << "Cannot open file " <<
>>>>> std::endl;
>>>>> return false;
>>>>> std::vector<Kernel::Point_3> points;
>>>>> std::vector< std::vector<std::size_t> > polygons;
>>>>> if (!CGAL::read_OBJ(input, points, polygons))
>>>>> std::cerr << "Error parsing the OFF file " <<
>>>>> std::endl;
>>>>> return false;
>>>>> //Mesh mesh;
>>>>> Polyhedron mesh;
>>>>> CGAL::Polygon_mesh_processing::orient_polygon_soup(points,
>>>>> polygons);
>>>>> CGAL::Polygon_mesh_processing::polygon_soup_to_polygon_mesh(points,
>>>>> polygons, mesh);
>>>>> bool solved =
>>>>> CGAL::Polygon_mesh_processing::remove_self_intersections(mesh);
>>>>> if (!solved)
>>>>> std::cout << "Some self-intersection could
>>>>> not
>>>>> be fixed" << std::endl;
>>>>> //return false;
>>>>> addStringToFileName(fileName, "_fixed.obj");
>>>>> std::ofstream ofs(fileName);
>>>>> CGAL::print_polyhedron_wavefront(ofs, mesh);
>>>>> clock_t end = clock();
>>>>> double elapsed_secs = double(end - begin) /
>>>>> CLOCKS_PER_SEC;
>>>>> std::cout << "Repairing time:.................." <<
>>>>> elapsed_secs << "
>>>>> seconds."<< std::endl;
>>>>> return true;
>>>>> int main(int argc, char* argv[])
>>>>> std::string fileName = argv[1];
>>>>> repairOBJFile(fileName);
>>>>> return 0;
>>>>> Sent from: http://cgal-discuss.949826.n4.nabble.com/
>>>>> <http://cgal-discuss.949826.n4.nabble.com/>
>>>>> -- You are currently subscribed to cgal-discuss.
>>>>> To unsubscribe or access the archives, go to
>>>>> https://sympa.inria.fr/sympa/info/cgal-discuss
>>>>> <https://sympa.inria.fr/sympa/info/cgal-discuss>
- [cgal-discuss] remove_self_intersections changes the mesh and the reparation is less when it is build in Release than when i build my application in Debug, sergio, 07/04/2018
- Re: [cgal-discuss] remove_self_intersections changes the mesh and the reparation is less when it is build in Release than when i build my application in Debug, Sebastien Loriot (GeometryFactory), 07/09/2018
- Re: [cgal-discuss] remove_self_intersections changes the mesh and the reparation is less when it is build in Release than when i build my application in Debug, sergio campo, 07/09/2018
- Re: [cgal-discuss] remove_self_intersections changes the mesh and the reparation is less when it is build in Release than when i build my application in Debug, Zesen Qian, 07/10/2018
- Re: [cgal-discuss] remove_self_intersections changes the mesh and the reparation is less when it is build in Release than when i build my application in Debug, Sebastien Loriot (GeometryFactory), 07/10/2018
- Re: [cgal-discuss] remove_self_intersections changes the mesh and the reparation is less when it is build in Release than when i build my application in Debug, sergio campo, 07/10/2018
- Re: [cgal-discuss] remove_self_intersections changes the mesh and the reparation is less when it is build in Release than when i build my application in Debug, Zesen Qian, 07/15/2018
- Re: [cgal-discuss] remove_self_intersections changes the mesh and the reparation is less when it is build in Release than when i build my application in Debug, sergio campo, 07/16/2018
