Re: [cgal-discuss] remove_self_intersections changes the mesh and the reparation is less when it is build in Release than when i build my application in Debug
- To:
- Subject: Re: [cgal-discuss] remove_self_intersections changes the mesh and the reparation is less when it is build in Release than when i build my application in Debug
- Date: Mon, 16 Jul 2018 10:37:07 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hello Zesen,
Thank you so much. Any ideas to solve these kind of complex files? What is the reason that they can not be fixed?
Best regards,
Sergio
On Sun, Jul 15, 2018 at 10:46 PM, Zesen Qian <> wrote:
Hi Sergio,
I tried it for you - remove_self_intersection can't fix it. There is
still numerous intersections left.
Also FYI, MeshFix can't fix it either - the output mesh is virtually
empty with only a simple convex.
Best,
Zesen
On Tue, Jul 10, 2018 at 11:42 AM, sergio campo <> wrote:
> Hello Sebastien,
> Could you please let me know if you can fix this complex file?
> https://drive.google.com/open?id=1BVs6x_VGx1RMGxC1BcGf_PCe-kLoTJBc
> I tried but it does not fixed it has 104106 intersected face of 104384 faces
> (99% of model)
> Thanks and best regards,
> Rubén
> On Tue, Jul 10, 2018 at 5:34 PM, Sebastien Loriot (GeometryFactory)
> <> wrote:
>> I never used MeshFix as I don't think there is a linux version.
>> If you have some hard to fix self-intersections I'm interested in
>> having a look and I'll let you know if CGAL can fix those.
>> You can send me the file off list if you don't want to spam the whole
>> list.
>> Thanks,
>> Sebastien.
>> On 07/10/2018 12:12 PM, Zesen Qian wrote:
>>> sorry, not try to hijack the thread, but how is this self-intersection
>>> fix method compared to MeshFix? I'm using the latter and it can't fix
>>> meshes with SI that's too complex.
>>> Best,
>>> Zesen
>>> On Mon, Jul 9, 2018 at 5:43 AM, Sebastien Loriot (GeometryFactory)
>>> <> wrote:
>>>> No on linux. The precompiled demo on windows is available here:
>>>> https://www.cgal.org/demo/4.12/polyhedron_3.zip
>>>> with common dlls (to be put in the same directy as Polyhedron_3.exe
>>>> in the aforementioned archive):
>>>> https://www.cgal.org/demo/4.12/CGAL-demoDLLs.zip
>>>> Sebastien.
>>>> On 07/09/2018 11:40 AM, sergio campo wrote:
>>>>> Thanks for your fast answer! :). I set std::setprecision(17) with the
>>>>> same results. Have you execute the demo with Windows? In my case I
>>>>> executed
>>>>> the program in Windows 10.
>>>>> On Mon, Jul 9, 2018 at 10:27 AM, Sebastien Loriot (GeometryFactory)
>>>>> < <mailto:>> wrote:
>>>>> No idea what you did, if I open the polyhedron demo, load your
>>>>> model
>>>>> call orient polygon soup and remove self intersections, everything
>>>>> is done in less than a minute on my computer and the output model
>>>>> does not
>>>>> contain any self-intersection.
>>>>> Do you have intermediate writing to "string" with a rounding of
>>>>> the
>>>>> coordinates of the point not using the max precision
>>>>> (std::setprecision(17) for the ostream)?
>>>>> Sebastien.
>>>>> On 07/04/2018 11:33 AM, sergio wrote:
>>>>> This is may application that i compile in windows in Release
>>>>> with the showed
>>>>> CMakeList.txt and cgal_vtk_test.cpp files. When I try to
>>>>> repair
>>>>> this file:
>>>>> Number intersection: 290
>>>>> https://drive.google.com/file/d/1uqcbZqgtbiiXYjKnzzb5d-OXm4JAHqdx/view?usp=sharing
>>>>> <https://drive.google.com/file/d/1uqcbZqgtbiiXYjKnzzb5d-OXm4JAHqdx/view?usp=sharing>
>>>>> 1. my application build in Release generate the following
>>>>> file:
>>>>> Number intersections: 179
>>>>> Add some visible holes and some deformations.
>>>>> Repairing time:..................201.128 seconds.
>>>>> https://drive.google.com/file/d/13Vfw0pP5Ymw0oo4RnfRjKTI_aTndb6P4/view?usp=sharing
>>>>> <https://drive.google.com/file/d/13Vfw0pP5Ymw0oo4RnfRjKTI_aTndb6P4/view?usp=sharing>
>>>>> 2. my application compiled in Debug, it generate the following
>>>>> file:
>>>>> Number intersections: 4
>>>>> Repairing time:..................1072.96 seconds.
>>>>> https://drive.google.com/file/d/1x1Z7qaNcnfGC8a24qzJI-DZEF3qqeLqq/view?usp=sharing
>>>>> <https://drive.google.com/file/d/1x1Z7qaNcnfGC8a24qzJI-DZEF3qqeLqq/view?usp=sharing>
>>>>> with warnings:
>>>>> _expression_ : !"Returning no output. Filling hole with extra
>>>>> triangles is not
>>>>> successful!"
>>>>> File :
>>>>> C:\dev\CGAL-4.12\include\CGAL/Polygon_mesh_processing/internal/Hole_filling/Triangulate_hole_polyline.h
>>>>> Line : 1103
>>>>> Explanation:
>>>>> Refer to the bug-reporting instructions at
>>>>> https://www.cgal.org/bug_report.html
>>>>> <https://www.cgal.org/bug_report.html>
>>>>> The problem is that in debug build it takes around 17 min for
>>>>> reparacion and
>>>>> in Release it only takes 3 minutes, but in relese build it
>>>>> modify the
>>>>> original mesh and add a big hole(pleas check links to files)
>>>>> What's wrong?
>>>>> CMakeList.txt
>>>>> cmake_minimum_required(VERSION 2.8.4)
>>>>> project( cgal_vtk_test )
>>>>> # Find CGAL
>>>>> find_package(CGAL REQUIRED COMPONENTS Core) # If the
>>>>> dependency
>>>>> is required,
>>>>> use REQUIRED option - if it's not found CMake will issue an
>>>>> error
>>>>> include( ${CGAL_USE_FILE} )
>>>>> # Find VTK
>>>>> find_package(VTK REQUIRED)
>>>>> include(${VTK_USE_FILE})
>>>>> # Setup your executable
>>>>> #include_directories (BEFORE "include")
>>>>> include( CGAL_CreateSingleSourceCGALProgram )
>>>>> create_single_source_cgal_program( "cgal_vtk_test.cpp" ) #
>>>>> This
>>>>> will create
>>>>> an executable target with name 'cgal_vtk_test'
>>>>> # Add VTK link libraries to your executable target
>>>>> target_link_libraries(cgal_vtk_test ${VTK_LIBRARIES})
>>>>> #target_link_libraries(cgal_vtk_test)
>>>>> cgal_vtk_test.cpp
>>>>> #include <fstream>
>>>>> #include <iomanip>
>>>>> #include <ctime>
>>>>> // CGAL
>>>>> #include <limits>
>>>>> #include <CGAL/Polygon_mesh_processing/repair.h>
>>>>> #include
>>>>> <CGAL/Polygon_mesh_processing/internal/repair_extra.h>
>>>>> #include <CGAL/Polygon_mesh_processing/corefinement.h>
>>>>> #include
>>>>> <CGAL/Polygon_mesh_processing/polygon_soup_to_polygon_mesh.h>
>>>>> #include <CGAL/Polyhedron_3.h>
>>>>> #include <CGAL/Surface_mesh/Surface_mesh.h>
>>>>> #include <CGAL/IO/print_wavefront.h>
>>>>> #include <CGAL/IO/OBJ_reader.h>
>>>>> #include <CGAL/assertions.h>
>>>>> #include <CGAL/IO/STL_reader.h>
>>>>> #include <CGAL/IO/STL_writer.h>
>>>>> typedef CGAL::Exact_predicates_inexact_constructions_kernel
>>>>> Kernel;
>>>>> typedef CGAL::Surface_mesh<Kernel::Point_3> Mesh;
>>>>> typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
>>>>> void addStringToFileName(std::string & fileName, const
>>>>> std::string & str)
>>>>> size_t lastindex = fileName.find_last_of(".");
>>>>> std::string name = fileName.substr(0, lastindex);
>>>>> fileName = name + str;
>>>>> bool repairOBJFile(std::string & fileName)
>>>>> clock_t begin = clock();
>>>>> std::cout << std::endl;
>>>>> std::cout <<
>>>>> << std::endl;
>>>>> std::cout << ". Repairing
>>>>> << std::endl;
>>>>> std::cout <<
>>>>> << std::endl;
>>>>> std::ifstream input(fileName);
>>>>> if (!input)
>>>>> std::cerr << "Cannot open file " <<
>>>>> std::endl;
>>>>> return false;
>>>>> std::vector<Kernel::Point_3> points;
>>>>> std::vector< std::vector<std::size_t> > polygons;
>>>>> if (!CGAL::read_OBJ(input, points, polygons))
>>>>> std::cerr << "Error parsing the OFF file " <<
>>>>> std::endl;
>>>>> return false;
>>>>> //Mesh mesh;
>>>>> Polyhedron mesh;
>>>>> CGAL::Polygon_mesh_processing::orient_polygon_soup(points,
>>>>> polygons);
>>>>> CGAL::Polygon_mesh_processing::polygon_soup_to_polygon_mesh(points,
>>>>> polygons, mesh);
>>>>> bool solved =
>>>>> CGAL::Polygon_mesh_processing::remove_self_intersections(mesh);
>>>>> if (!solved)
>>>>> std::cout << "Some self-intersection could
>>>>> not
>>>>> be fixed" << std::endl;
>>>>> //return false;
>>>>> addStringToFileName(fileName, "_fixed.obj");
>>>>> std::ofstream ofs(fileName);
>>>>> CGAL::print_polyhedron_wavefront(ofs, mesh);
>>>>> clock_t end = clock();
>>>>> double elapsed_secs = double(end - begin) /
>>>>> CLOCKS_PER_SEC;
>>>>> std::cout << "Repairing time:.................." <<
>>>>> elapsed_secs << "
>>>>> seconds."<< std::endl;
>>>>> return true;
>>>>> int main(int argc, char* argv[])
>>>>> std::string fileName = argv[1];
>>>>> repairOBJFile(fileName);
>>>>> return 0;
>>>>> Sent from: http://cgal-discuss.949826.n4.nabble.com/
>>>>> <http://cgal-discuss.949826.n4.nabble.com/>
>>>>> -- You are currently subscribed to cgal-discuss.
>>>>> To unsubscribe or access the archives, go to
>>>>> https://sympa.inria.fr/sympa/info/cgal-discuss
>>>>> <https://sympa.inria.fr/sympa/info/cgal-discuss>
- [cgal-discuss] remove_self_intersections changes the mesh and the reparation is less when it is build in Release than when i build my application in Debug, sergio, 07/04/2018
- Re: [cgal-discuss] remove_self_intersections changes the mesh and the reparation is less when it is build in Release than when i build my application in Debug, Sebastien Loriot (GeometryFactory), 07/09/2018
- Re: [cgal-discuss] remove_self_intersections changes the mesh and the reparation is less when it is build in Release than when i build my application in Debug, sergio campo, 07/09/2018
- Re: [cgal-discuss] remove_self_intersections changes the mesh and the reparation is less when it is build in Release than when i build my application in Debug, Zesen Qian, 07/10/2018
- Re: [cgal-discuss] remove_self_intersections changes the mesh and the reparation is less when it is build in Release than when i build my application in Debug, Sebastien Loriot (GeometryFactory), 07/10/2018
- Re: [cgal-discuss] remove_self_intersections changes the mesh and the reparation is less when it is build in Release than when i build my application in Debug, sergio campo, 07/10/2018
- Re: [cgal-discuss] remove_self_intersections changes the mesh and the reparation is less when it is build in Release than when i build my application in Debug, Zesen Qian, 07/15/2018
- Re: [cgal-discuss] remove_self_intersections changes the mesh and the reparation is less when it is build in Release than when i build my application in Debug, sergio campo, 07/16/2018
