- To:
- Subject: Re: [cgal-discuss] Poygon mesh creation with PMP
- Date: Wed, 15 Aug 2018 12:28:48 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:tjN/3RCYcmdE7s9xRFiUUyQJP3N1i/DPJgcQr6AfoPdwSPT7rsbcNUDSrc9gkEXOFd2Cra4c1ayO6+jJYi8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tL1LdrWev4jEMBx7xKRR6JvjvGo7Vks+7y/2+94fcbglUhTexe69+IAmrpgjNq8cahpdvJLwswRXTuHtIfOpWxWJsJV2Nmhv3+9m98p1+/SlOovwt78FPX7n0cKQ+VrxYES8pM3sp683xtBnMVhWA630BWWgLiBVIAgzF7BbnXpfttybxq+Rw1DWGMcDwULs5Xymp4aV2Rx/ykCoJKiA38G/XhMJzgqxUrh2uqB5jzIDbe4yVKPhzc7nBcd8GS2dMXMBcXDFBDIOmaIsPCvIMMehFoYbjvFQBtwC+BRWtBOzxzD9Dm3n43aog0+QgFgHGwBErE9YPvnvKq9X1MbkdUfyvzKjIzTvMde9Z2Sv66IjSchEtpP+AVq93fMrKzUkvEBnFjlSXqYz5JT+V0+ANvnOU7+plT+2vimonpxttrTiow8chk4/EjZ8WxFDc7Sh13po5KNmiREN4YdOoCoVcuz+HO4dsTc4vR3lktSQ5x7Ecp5K2cykHxI46yxPbZfGLaYqF7xLlWe2MOzl3nmhld6i6hxuq8Uiv1On8Vs6s3VZPtCVFk93MumkD1hzJ98SLU/V980il1DqV2ADT7eZEIU8wlaXFMZIu3rkwlp8LvUTCGC/5hln2gbeIekk4/uWk8efqb7X8qpOCKYN4lxvyP6sql8CnBOQ3KAkOX2yV+eSm073j+FX0QK5Ojv0xiKnZsZfaJdgBqq68Bw9YyYkj6xOlADen1NQUh2UILFVAeB6flYjmJ0nOIOzkDfe4m1mjjDhryOrCPrH4H5rNL2PDn6v8fbZm8E5R0xEzzNBa55JMEL4NOvPzWknrtNzZFBA1KQK0w/y0QOl6g4gRUGbKDq6CO77JqneJ4PguKq+Cftw7ojH4frIe6vTnlmM4lFlVWa6z3JwLIDCXE/NjLlmDcFTlicsGC3ZL9EJqV+jtklyFTXhWY169Wqs94ncwD4fwXtSLfZyknLHUhHTzJZZRfG0TUgndQ0etTJ2NXrI3UAzXJ8ZgljIeUr34Et0u0BivsEnxzL81d7OIqB1djorq0Z1O38OWjQs7rGUmAMGU0mXLRGZxzDtRGm0GmZtnqEk48W+tlKh1h/sCSI5W7vJNFxggbNvSk708BNf1VQbMONyOTQT+Tw==
You probably have some non-manifold faces in your soup. If this is the case, it probably needs some clean up. Can you share the input so that
we can give more info?
Sebastien.
On 08/14/2018 10:05 AM,
wrote:
Hello,
I'm trying to use the CGAL's PMP package to create a mesh out of a polygon soup (extracted from a spatial subdivision structure using a min-cut approach). I've usedorient_polygon_soup() and polygon_soup_to_polygon_mesh(). A subsequent call to is_polygon_soup_a_polygon_mesh() return true, but the mesh produced is not closed. This also creates problems when using other functions of the package, such as
is_outward_oriented()/reverse_face_orientations(). Also using stitch_borders did not improve the mesh.
Is this the expected behaviour of the functions?
Thanks,
Claudio
- [cgal-discuss] Poygon mesh creation with PMP, mura . cld, 08/14/2018
- Re: [cgal-discuss] Poygon mesh creation with PMP, Sebastien Loriot (GeometryFactory), 08/15/2018
- Re: [cgal-discuss] Poygon mesh creation with PMP, mura . cld, 08/15/2018
- Re: [cgal-discuss] Poygon mesh creation with PMP, Sebastien Loriot (GeometryFactory), 08/16/2018
- Re: [cgal-discuss] Poygon mesh creation with PMP, mura . cld, 08/16/2018
- Re: [cgal-discuss] Poygon mesh creation with PMP, Sebastien Loriot (GeometryFactory), 08/20/2018
