- To:
- Subject: [cgal-discuss] Poygon mesh creation with PMP
- Date: Tue, 14 Aug 2018 10:05:20 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hello,
I'm trying to use the CGAL's PMP package to create a mesh out of a polygon soup (extracted from a spatial subdivision structure using a min-cut approach). I've used orient_polygon_soup() and polygon_soup_to_polygon_mesh(). A subsequent call to is_polygon_soup_a_polygon_mesh() return true, but the mesh produced is not closed. This also creates problems when using other functions of the package, such as
is_outward_oriented()/reverse_face_orientations(). Also using stitch_borders did not improve the mesh.
Is this the expected behaviour of the functions?
Thanks,
Claudio
- [cgal-discuss] Poygon mesh creation with PMP, mura . cld, 08/14/2018
- Re: [cgal-discuss] Poygon mesh creation with PMP, Sebastien Loriot (GeometryFactory), 08/15/2018
- Re: [cgal-discuss] Poygon mesh creation with PMP, mura . cld, 08/15/2018
- Re: [cgal-discuss] Poygon mesh creation with PMP, Sebastien Loriot (GeometryFactory), 08/16/2018
- Re: [cgal-discuss] Poygon mesh creation with PMP, mura . cld, 08/16/2018
- Re: [cgal-discuss] Poygon mesh creation with PMP, Sebastien Loriot (GeometryFactory), 08/20/2018
