- To:
- Subject: [cgal-discuss] Fw: Re:Re: 1D Combinatorial Map - 1-Simplex
- Date: Wed, 29 Aug 2018 12:41:44 +0800 (GMT+08:00)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
- Ironport-phdr: 9a23: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
Hi,
Sorry for my mistake! Please delete or just ignor it.
Xianliang Hu
-----原始邮件-----
发件人: xlhu
发送时间: 2018-08-29 12:36:01 (星期三)
收件人: cgal-discuss
抄送:
主题: Re:Re: [cgal-discuss] 1D Combinatorial Map - 1-Simplex
盖的是数学学院的章,虽然说录取的可能性非常大,但最终解释权应该是浙大研究生院。首先你需要获得吉大的推免资格。
所以,我说若是上报吉大教务处,你就填我的名字没问题。 浙大的面试开学你还需要再过来的话,我还是希望能方面跟你聊一聊的。
在 2018-08-29 12:13:15,"Peter Klosowski"
写道:
>Hi,
>Just following up on this, since I am feeling quite stuck. Is there anybody
>who could answer the following question?
>1) Should it be possible to construct a 1D combinatorial map with the
>following characteristics?
>#Darts=2, #0-cells=2, #1-cells=1, #ccs=1
>Bonus questions:
>1a) If yes, what is the correct code to construct such a combinatorial map?
>1b) If no, what is the best representation of a 1-simplex (1d line segment)?
>Any advice would be greatly appreciated. Thank you in advance!
>Cheers,
>Peter
>On Mon, Aug 27, 2018 at 5:58 PM Peter Klosowski
> wrote:
>Hi Guillaume,
>Many thanks for your suggestions! However, I am still a bit confused. I
>tried your code:
> CGAL::Combinatorial_map<1> cm;
> auto dh1 = cm.create_dart();
> auto dh2 = cm.create_dart();
> cm.dart_link_beta<1>(dh1, dh2);
> cm.display_characteristics(std::cout);
> std::cout << std::endl;
>But it still gives me:
>#Darts=2, #0-cells=2, #1-cells=2, #ccs=1
>Am I wrong to expect that an edge would only have a single 1-cell? My
>expectation comes from the faces of a 1-simplex
>(https://en.wikipedia.org/wiki/Simplex). Perhaps in combinatorial maps it
>works differently...
>I think the main challenge for me in terms of forming an intuition is to
>understand the different betas. I can see the value of combinatorial maps to
>represent cellular structures, and a lot of the concepts and operations make
>sense. I am just having trouble getting my head around why an edge is made
>of two darts linked by beta1, as opposed to beta0, for example?
>I hope some of that makes sense. Thank you again for the help!
>Cheers,
>Peter
>On Mon, Aug 27, 2018 at 4:43 PM Guillaume Damiand
> wrote:
>Hi Peter;
>Le 26/08/2018 à 13:41, kloffy a écrit :
>> Hi,
>> I am trying to get my head around combinatorial maps, and I thought I would
>> start with the simplest non-trivial example, a 1-simplex (#0-cells=2,
>> #1-cells=1).
>> So, first I tried the obvious construction helper:
>> cm.make_edge();
>> However, this gives me:
>> #Darts=2, #0-cells=2, #1-cells=2, #ccs=2
>> But that's not quite right (#1-cells=2).
>A 1D combinatorial map can be seen as a set of 1D curves (possibly opened).
>As said in the doc of make_edge (here
>https://doc.cgal.org/latest/Combinatorial_map/classGenericMap.html#a6f455fd64b650495392bddecedbd5afe),
>this method requires that the dimension of the combinatorial map n is >= 2.
>Indeed, an edge is made of two darts linked by beta2 and this requires n>=2.
>In a 1D cmap, an edge is made of two darts linked by beta1. If you want
>to create such an edge by hand, you must use
>To have an intuition of what is a combinatorial map, have a look at the
>2 first figures in the user manual (here
>https://doc.cgal.org/latest/Combinatorial_map/index.html).
>Hope this help.
>Best
>Guillaume
>> So I tried creating the 1-simplex manually:
>> But that's still not quite right (#1-cells=2).
>> I tried a bunch of other things, but I never managed to get the intended
>> result (#1-cells=1). My intuition for combinatorial maps is still very
>> poor,
>> which was the motivation for this exercise. At this point, I feel like I
>> must be missing something. Please forgive me if it is something very
>> obvious. Still, I would appreciate any hints...
>> Cheers,
>> Peter
>> Sent from: http://cgal-discuss.949826.n4.nabble.com/
>Guillaume DAMIAND
>CNRS - LIRIS UMR 5205
>Université Claude Bernard
>Bâtiment Nautibus (710)
>43 Boulevard du 11 Novembre 1918
>69622 Villeurbanne Cedex (France)
>Tél: +33 (0)4.72.43.14.34 Fax: +33 (0)4.72.43.15.36
>Mail:
>Web: http://liris.cnrs.fr/guillaume.damiand/
- [cgal-discuss] Fw: Re:Re: 1D Combinatorial Map - 1-Simplex, xlhu, 08/29/2018
