cgal-discuss - Re: [cgal-discuss] 1D Combinatorial Map - 1-Simplex
  • To:
  • Subject: Re: [cgal-discuss] 1D Combinatorial Map - 1-Simplex
  • Date: Wed, 29 Aug 2018 08:01:53 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23: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
Hi Peter;
If your goal is to understand the mean of the different beta, I suggest you to start in 2D, and study the examples given in the CGAL user manual.
Indeed, 1D combinatorial map with boundaries (which is what you try to do) is a very special case.
For this reason, it is not possible to build a 1D cmap with #Darts=2, #0-cells=2, #1-cells=1, #ccs=1 because 1 dart represents one 0-cell and one 1-cell. But this is possible in a 2D combinatorial map, as said in my previous email, by creating 2 darts linked by beta2.
In my point of view, this is not a problem because 1D combinatorial map is a very special case, not really interesting. To represend 1D line segment, you can simply use a polygon representation based on vertices and edges.
Best
Guillaume
Le 29/08/2018 à 06:13, Peter Klosowski a écrit :
Hi,
Just following up on this, since I am feeling quite stuck. Is there anybody who could answer the following question?
1) Should it be possible to construct a 1D combinatorial map with the following characteristics?
Bonus questions:
1a) If yes, what is the correct code to construct such a combinatorial map?
1b) If no, what is the best representation of a 1-simplex (1d line segment)?
Any advice would be greatly appreciated. Thank you in advance!
Cheers,
Peter
On Mon, Aug 27, 2018 at 5:58 PM Peter Klosowski <> wrote:
Hi Guillaume,
Many thanks for your suggestions! However, I am still a bit confused. I tried your code:
    CGAL::Combinatorial_map<1> cm;
    auto dh1 = cm.create_dart();
    auto dh2 = cm.create_dart();
    cm.dart_link_beta<1>(dh1, dh2);
    cm.display_characteristics(std::cout);
    std::cout << std::endl;
But it still gives me:
#Darts=2, #0-cells=2, #1-cells=2, #ccs=1
Am I wrong to expect that an edge would only have a single 1-cell? My expectation comes from the faces of a 1-simplex (https://en.wikipedia.org/wiki/Simplex). Perhaps in combinatorial maps it works differently...
I think the main challenge for me in terms of forming an intuition is to understand the different betas. I can see the value of combinatorial maps to represent cellular structures, and a lot of the concepts and operations make sense. I am just having trouble getting my head around why an edge is made of two darts linked by beta1, as opposed to beta0, for example?
I hope some of that makes sense. Thank you again for the help!
Cheers,
Peter
On Mon, Aug 27, 2018 at 4:43 PM Guillaume Damiand <> wrote:
Hi Peter;
Le 26/08/2018 à 13:41, kloffy a écrit :
> Hi,
> I am trying to get my head around combinatorial maps, and I thought I would
> start with the simplest non-trivial example, a 1-simplex (#0-cells=2,
> #1-cells=1).
> So, first I tried the obvious construction helper:
> cm.make_edge();
> However, this gives me:
> #Darts=2, #0-cells=2, #1-cells=2, #ccs=2
> But that's not quite right (#1-cells=2).
A 1D combinatorial map can be seen as a set of 1D curves (possibly opened).
As said in the doc of make_edge (here
https://doc.cgal.org/latest/Combinatorial_map/classGenericMap.html#a6f455fd64b650495392bddecedbd5afe),
this method requires that the dimension of the combinatorial map n is >= 2.
Indeed, an edge is made of two darts linked by beta2 and this requires n>=2.
In a 1D cmap, an edge is made of two darts linked by beta1. If you want
to create such an edge by hand, you must use
To have an intuition of what is a combinatorial map, have a look at the
2 first figures in the user manual (here
https://doc.cgal.org/latest/Combinatorial_map/index.html).
Hope this help.
Best
Guillaume
> So I tried creating the 1-simplex manually:
> But that's still not quite right (#1-cells=2).
> I tried a bunch of other things, but I never managed to get the intended
> result (#1-cells=1). My intuition for combinatorial maps is still very poor,
> which was the motivation for this exercise. At this point, I feel like I
> must be missing something. Please forgive me if it is something very
> obvious. Still, I would appreciate any hints...
> Cheers,
> Peter
> Sent from: http://cgal-discuss.949826.n4.nabble.com/
Guillaume DAMIAND
CNRS - LIRIS UMR 5205
Université Claude Bernard
Bâtiment Nautibus (710)
43 Boulevard du 11 Novembre 1918
69622 Villeurbanne Cedex (France)
Tél: +33 (0)4.72.43.14.34                 Fax: +33 (0)4.72.43.15.36
Mail:
Web: http://liris.cnrs.fr/guillaume.damiand/
Attachment: smime.p7s
Description: Signature cryptographique S/MIME
