cgal-discuss - [cgal-discuss] How to get all vertices that located between two lines in the arrangement?
  • To:
  • Subject: [cgal-discuss] How to get all vertices that located between two lines in the arrangement?
  • Date: Tue, 25 Sep 2018 18:29:41 +0330
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Hi,
I want to discover all intersection points or vertices that located between two lines in the arrangement but I don't know how to do this. I think one way to do this is to use the overlay function but I don't how to make second arrangement for use in overlay function so that all vertices between the two lines exist in the overlaid arrangement.
Thanks.
