cgal-discuss - Re: [cgal-discuss] How to get all vertices that located between two lines in the arrangement?
  • To:
  • Subject: Re: [cgal-discuss] How to get all vertices that located between two lines in the arrangement?
  • Date: Tue, 25 Sep 2018 17:32:39 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
What is your input? you have a set of points and 2 lines and what to get
all the points between the two lines? Or it is something more complicated?
Sebastien.
On 09/25/2018 04:59 PM, Morteza Manavi wrote:
Hi,
I want to discover all intersection points or vertices that located between two lines in the arrangement but I don't know how to do this. I think one way to do this is to use the overlay function but I don't how to make second arrangement for use in overlay function so that all vertices between the two lines exist in the overlaid arrangement.
Thanks.
