- To:
- Subject: Re: [cgal-discuss] Load a mesh in Gmsh format
- Date: Thu, 8 Nov 2018 22:45:03 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=Pass
- Ironport-phdr: 9a23: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
Hello everybody out there!
On 2018/11/08 at 6:34 pm, Chris Marsh wrote:
> Oh no! That is my SO answer...
Well, everyone can do a mistake, especially me. Still, thank you for
the answer on Stackoverflow and here, it does help.
> In my code I took this from, I extent the
> vertex_base class to allow for storing more information within the node.
> I forgot to remove that when I wrote that answer.
> I've updated it to correct this.
Thank you for this. I think there is still one line specific to your
code. I cannot compile it anyway. Here is the line:
typedef face<Gt> Fb; //custom face class, use default face and vertex as
required
According to your comment, I should be using the default face class.
The thing is, I am discovering CGAL and I have not been able to find
which one I should use.
> I would look here
> http://gmsh.info/doc/texinfo/gmsh.html#MSH-file-format-_0028version-4_0029
> and figure out how it's stored -- I'm not sure which of these formats
> you have
Yes, indeed. Anyway, I do master the mesh formats I am dealing with.
Right now, my trouble is, I am discovering CGAL and as it is quite an
extensive library, I am still a bit lost in it.
Once again, thank you for your answer.
Best regards.
Yoann LE BARS
http://le-bars.net/yoann/
Diaspora* :
- [cgal-discuss] Load a mesh in Gmsh format, Yoann LE BARS, 11/08/2018
- Re: [cgal-discuss] Load a mesh in Gmsh format, Chris Marsh, 11/08/2018
- Re: [cgal-discuss] Load a mesh in Gmsh format, Yoann LE BARS, 11/08/2018
- Re: [cgal-discuss] Load a mesh in Gmsh format, Yoann LE BARS, 11/09/2018
- Re: [cgal-discuss] Load a mesh in Gmsh format, Chris Marsh, 11/09/2018
