- To: <>
- Subject: Re: [cgal-discuss] Load a mesh in Gmsh format
- Date: Fri, 9 Nov 2018 11:50:19 -0600
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
- Ironport-phdr: 9a23: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
Hi Yoann,
Great to hear that example is working and your code is also compiling.
Cheers
Chris
Hello everybody out there!
Le 09/11/2018 à 12:10, Yoann LE BARS a écrit :
> Still, I have this compilation error on my own code:
Well, I had to walk away right after I sent this e-mail and the
solution popped in my mind (always go for a walk when you face some
blocking situation). Here is a corrected code:
std::vector<Vertex> vertex (x.size());
for (std::size_t i = 0; i < x.size(); ++i) {
// Current point coordinates.
const Point3 p (x[i], y[i], 0.);
vertex[i] = mesh.create_vertex();
vertex[i]->set_point(p);
As Chris mentioned, the vertex is stocked as a pointer. Therefore, you
have to use it as a pointer, not a variable …
Well, problem solved and my thanks to Chris.
Best regards.
Yoann LE BARS
http://le-bars.net/yoann
*Diaspora :
- [cgal-discuss] Load a mesh in Gmsh format, Yoann LE BARS, 11/08/2018
- Re: [cgal-discuss] Load a mesh in Gmsh format, Chris Marsh, 11/08/2018
- Re: [cgal-discuss] Load a mesh in Gmsh format, Yoann LE BARS, 11/08/2018
- Re: [cgal-discuss] Load a mesh in Gmsh format, Yoann LE BARS, 11/09/2018
- Re: [cgal-discuss] Load a mesh in Gmsh format, Chris Marsh, 11/09/2018
