Re: [cgal-discuss] How I can convert .mesh format to .obj format in 3D mesh generation
- To:
- Subject: Re: [cgal-discuss] How I can convert .mesh format to .obj format in 3D mesh generation
- Date: Thu, 29 Nov 2018 11:31:27 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
AFAIK obj files can only store polygon meshes and not tetrahedral meshes. Are you only interested to get the boundary surfaces?
If yes then the function CGAL::facets_in_complex_3_to_triangle_mesh()
will create an OFF file containing what you want.
https://doc.cgal.org/latest/Mesh_3/group__PkgMesh__3Functions.html#ga68ca38989087644fb6b893eb566be9ea
You can either copy and adapt that function to write an OBJ or
use another code converting OFF to OBJ.
Sebastien.
On 11/12/18 9:40 AM, Davic wrote:
Hello everyone!
I am a new CGAl user. I use 3D mesh generation to get a .mesh format. But I
want .obj format.
Can you tall me how I can do? Or what kind of software do I need?
Best regards.
- [cgal-discuss] How I can convert .mesh format to .obj format in 3D mesh generation, Davic, 11/12/2018
- Re: [cgal-discuss] How I can convert .mesh format to .obj format in 3D mesh generation, Sebastien Loriot (GeometryFactory), 11/29/2018
