cgal-discuss - Re: [cgal-discuss] Apollonius_graph_2 demo
  • To:
  • Subject: Re: [cgal-discuss] Apollonius_graph_2 demo
  • Date: Thu, 29 Nov 2018 11:34:37 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
What happens when you do Edit -> Insert Random Points?
I don't think the demo is doing more that that or you
can load points from a file.
Sebastien.
On 11/28/18 3:38 AM, Christian Jung wrote:
Hey,
I am trying to install the current version of CGAL (4.13) on my home computer running Ubuntu 16.04.
The build process worked so far.
When trying to make the Apollonius_graph_2 demo and run it I get the GUI attached in this email. It does not work properly. I installed CGAL 4.6.3 on the computer of the institute where I work and I know that the output application should have more feautures. In the output attached in this email there are serveral buttons missing. Yet, drawing apollonius diagrams works.
Is it possible that a library is missing on my computer?
Best regards
Chris
