- To: "" <>
- Subject: AW: [cgal-discuss] Apollonius_graph_2 demo
- Date: Thu, 29 Nov 2018 14:11:36 +0000
- Accept-language: de-DE, en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
- Ironport-phdr: 9a23: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
Insert random points works just fine (see attachment).
See also the demo of Apollonius_graph_2 of CGAL version 4.6.3.
It might have something to do with Qt3 as demos using it were removed in CGAL 4.8 or so.
What still bothers me is the fact that in the new demo a) the save button won't work (if pressed nothing happens) and b) the demo only shows the apollonius diagram, not the apollonius graph.
Von: <> im Auftrag von Sebastien Loriot (GeometryFactory) <>
Gesendet: Donnerstag, 29. November 2018 11:34
An:
Betreff: Re: [cgal-discuss] Apollonius_graph_2 demo
An:
What happens when you do Edit -> Insert Random Points?
I don't think the demo is doing more that that or you
can load points from a file.
Sebastien.
On 11/28/18 3:38 AM, Christian Jung wrote:
> Hey,
> I am trying to install the current version of CGAL (4.13) on my home
> computer running Ubuntu 16.04.
> The build process worked so far.
> When trying to make the Apollonius_graph_2 demo and run it I get the GUI
> attached in this email. It does not work properly. I installed CGAL
> 4.6.3 on the computer of the institute where I work and I know that the
> output application should have more feautures. In the output attached in
> this email there are serveral buttons missing. Yet, drawing apollonius
> diagrams works.
> Is it possible that a library is missing on my computer?
> Best regards
> Chris
Sebastien.
> Hey,
> diagrams works.
> Best regards
> Chris
Description: Screenshot from 2018-11-29 14-54-45.png
Description: Screenshot from 2018-11-29 14-56-01.png
- [cgal-discuss] Apollonius_graph_2 demo, Christian Jung, 11/28/2018
- Re: [cgal-discuss] Apollonius_graph_2 demo, Ujjval Rathod, 11/28/2018
- Re: [cgal-discuss] Apollonius_graph_2 demo, Sebastien Loriot (GeometryFactory), 11/29/2018
- AW: [cgal-discuss] Apollonius_graph_2 demo, Christian Jung, 11/29/2018
