cgal-discuss - [cgal-discuss] Optimal Transportation Curve Reconstruction-"CGAL ERROR:assertion violation!"
  • To:
  • Subject: [cgal-discuss] Optimal Transportation Curve Reconstruction-"CGAL ERROR:assertion violation!"
  • Date: Fri, 11 Jan 2019 03:41:52 -0600 (CST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
  • Ironport-phdr: 9a23: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
Hi there,
I've run into an assertion violation when I used CGAL/Optimal Transportation
Curve
Reconstruction(https://doc.cgal.org/latest/Optimal_transportation_reconstruction_2/index.html#Chapter_Optimal_Transportation_Curve_Reconstruction)
for 2D point reconstruction. The data I used is a set of simple 2D points
(already uploaded: 63_2D_points.txt
<http://cgal-discuss.949826.n4.nabble.com/file/t376067/63_2D_points.txt> ).
The program I used is the demo in CGAL-4.13/examples/Optimal Transportation
Curve Reconstruction_2/otr2_list_output_examples.cp. The main content is as
follows:
load_xy_file(filesPath, points);
Otr_2 otr2(points);
otr2.run_under_wasserstein_tolerance(0.8);
list_output(otr2);
The data I used is a very simple set of 2D points. What is the cause of this
assertion error? How can I avoid this assertion error?
Thanks!
