Re: [cgal-discuss] Optimal Transportation Curve Reconstruction-"CGAL ERROR:assertion violation!"
- To:
- Subject: Re: [cgal-discuss] Optimal Transportation Curve Reconstruction-"CGAL ERROR:assertion violation!"
- Date: Thu, 17 Jan 2019 00:10:27 -0600 (CST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
- Ironport-phdr: 9a23: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
I open an issue for this problem, and the link is
https://github.com/CGAL/cgal/issues/3601
<https://github.com/CGAL/cgal/issues/3601>
- [cgal-discuss] Optimal Transportation Curve Reconstruction-"CGAL ERROR:assertion violation!", hexudong, 01/11/2019
- Re: [cgal-discuss] Optimal Transportation Curve Reconstruction-"CGAL ERROR:assertion violation!", hexudong, 01/15/2019
- Re: [cgal-discuss] Optimal Transportation Curve Reconstruction-"CGAL ERROR:assertion violation!", Sebastien Loriot (GeometryFactory), 01/15/2019
- Re: [cgal-discuss] Optimal Transportation Curve Reconstruction-"CGAL ERROR:assertion violation!", hexudong, 01/16/2019
- Re: [cgal-discuss] Optimal Transportation Curve Reconstruction-"CGAL ERROR:assertion violation!", Sebastien Loriot (GeometryFactory), 01/16/2019
- Re: [cgal-discuss] Optimal Transportation Curve Reconstruction-"CGAL ERROR:assertion violation!", hexudong, 01/17/2019
- Re: [cgal-discuss] Optimal Transportation Curve Reconstruction-"CGAL ERROR:assertion violation!", johnzjq, 01/16/2019
